| | | Forums66 Topics128,206 Posts1,057,440 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Does anyone know what size lines and what types of flares we need?
1953 GMC 1-Ton Pickup with 350 and 700R4
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | 45° double flare, with male threaded tube nuts, they fit in "inverted flare" fittings.
Originally I know it was 1/4" line for most if not all, and if not for everything then there was some 3/16"?? It's been about 11 years since I replaced mine and I went with a different configuration with disc brakes. Perhaps someone else can recall exactly what size line where, if any 3/16 was used.
Grigg | | | | | Joined: Jul 2015 Posts: 203 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 203 | Thanks! Does anyone have a source for rebuilt or new wheel cylinders for a 53 GMC 1-ton? Or do most guys rebuild theirs?
| | | | | Joined: Dec 2011 Posts: 241 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 241 | Im pretty sure Rock Auto carries both the kits or new cylinders. Make sure you check the size bore you need to make sure your getting the right size. I believe others have also mentioned Napa as well.
Mark | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | |
