2 members (Otto Skorzeny, 1 invisible),
92
Mod | | | Forums66 Topics128,031 Posts1,055,433 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2014 Posts: 75 'Bolter | | 'Bolter Joined: May 2014 Posts: 75 | I have searched the "engine" forum and can't find an answer so I'm posting this question: I'm painting my engine while its still in the truck and can only find spray cans of the greyish color, I'm using Duplicolor "new Ford grey". I'd like to find the same color in a pint or quart, that would make it easier to apply in some areas, with a brush...less chance of overspray, mostly to use on the block. Does the paint have to be specifically for an engine or can I go to my local auto parts/auto paint store and get them to make me up a quart that is the same color? I don't know much about paint, but I would assume that there would have to be some chemicals in it to be heat resistant... maybe I'm wrong. I would like to know before I go to the auto parts store and sound like an idiot! Thanks in advance for the replies I know I will get! Brad. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Duplicolor's 7272 Ford Gray 500 degree engine paint in spray cans is what I assume you are using. You can go with Bill Hirsch Engine Paint (google) and get the exact correct color (which is really not been agreed upon) and then you can get pints or quarts.
What I did for my test engine, was the same thing you are doing, THEN, spray some paint in the cap and brush it on if you want. Its alot cheaper than the alternatives. On my project engine, I went with Bill Hirsch. Much better paint color. Engines require touchup from time to time. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do/did you use a primer under the finish coat? If yes, what do/did you use?
Have you driven an engine that had that primer/paint application (how many miles/hours/years), and how did it hold up?
Thanks, | | | | | Joined: Jun 2015 Posts: 4 New Guy | | New Guy Joined: Jun 2015 Posts: 4 | You might take a look at Jim Carter site, oldchevytrucks.com, look under paint section. Engines, manifolds. Grey, quarts, heat resistant, brushable.
55 3100 standard cab
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Yeah, what he said! The best universal primer to use under engine paint is epoxy primer. It has the same 500 degree characteristics and sticks to rattle can and anything in between. I got that from the local PPG supplier. | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | I degreased with a steam Jenny, brushed on Ospho, after 24 hours I wiped it down with a rag wet with Ospho to remove the white chalky deposits, primed with Rustoleum High Temp engine primer, then painted with the dark gray engine paint from Thefillingstation.com. Three years later and it still looks like new.
| | | | | Joined: May 2014 Posts: 75 'Bolter | | 'Bolter Joined: May 2014 Posts: 75 | No I did not use a primer, I just thoroughly cleaned the block and then sprayed it with the rattle can, three coats. Again my question, would normal automotive paint work, get a quart made up, or... does the paint have to be specifically made for an engine and the temperatures it runs at? I want to be able to brush the paint on in the areas that are hard to reach with a spray can (engine is still in the truck) Brad. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I painted my 1935 Chevy Coupe engine with Bill Hirsch Chevy Gray over 30 years ago and it still looks good. Cleaned everything with degreaser and lacquer thinner and brushed it on (no primer). It flows out nice without leaving any brush marks and touches up easy. Mike B  | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Yes Brad. You need specific engine paint. It needs to be rated at 500 degrees. Otherwise it will deteriorate much faster. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | If my engine gets to be 500°F.....I'm in deep dodo!!! Make life simple, paint it with the correct factory color for an AD engine, which is available only from The Filling Station as Carl posted yesterday. They were never primer before painting from the factory. Here's Filling Station's Factory original shade gray paint on a bare cast iron block and head and bare sheet metal that is about five years old, and driven on regular basis. She may not be the best dressed gal at the ball, but she still turns a head or two: http://www.pbase.com/dennygraham/image/160748815 http://www.pbase.com/dennygraham/image/160748816dg
Denny G Sandwich, IL
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Me too Tim, Denny has a pretty engine there, but no way is that blueish gray even close to every other vendor that swears theirs is THE correct color. But really its not worth arguing over. Nobody has proof.
500 degree engine paint is insurance, and it also improves longevity of the paint over lower temp heat cycles. Get the proper engine paint and do it YOUR way. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Duplicolor's 7272 Ford Gray 500 degree engine paint in spray cans not correct | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Yeah, nobody ever said that Ford Gray is correct. Its what the OP painted his engine with. I did the same on my test engine just due to expedience. Its staying in the shop. | | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | To the temperature debate, I agree with Denny that the engine in totality is never going to approach 500 degrees.
However, I would presume that the block surface near the exhaust manifold gets pretty doggone hot. Correct assumption?
Whatever it's rated for, the filling station paint has held up nicely.
1951 3100
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | As far as I know, it's a given that "engine paint" is 500 degrees. My Bill Hirsch engine paint is 500, even Duplicolor is 500. They do this for the reason you just mentioned.
I noticed in looking over Dennys blue gray that Bill Hirsch's has a blue tint to it as well but not nearly as pronounced. Depending on what kind of lighting you have in the shop, who knows what you are going to see. In any case, everyone can probably agree that Ford Gray is too light.
Tims response to his posted article above really tells the whole story in the clearest detail we have. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Duplicolor's 7272 Ford Gray 500 degree engine paint in spray cans not correct No such color Maybe DE1611 | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | Do not make the mistake that thefillinstation.com's color has even a hint of blue in it, as it does not! It can be better described as "light black" rather than "dark gray". Computers are horrible for judging colors. The three original AD 216s which I have seen with my own eyes were even darker than that, and had no sheen to it. In areas where the paint was missing and was soaked with a layer of dirty oil, looked almost identical to the painted surface. Carl
| | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | DG, you need to loosen a few stove bolts on the side cover to get that factory-correct leaky look.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Nice looking engine and color (color for a 216 - or low pressure 235).  | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Oh it's getting there Carl. I just wiped a little of the bulk off cuz we had to part next to one of those $49,000 hot rods last month at a cruse night. They were all dressed in their evening gowns and old blue was still in her house dress you know. dg
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Here’s a series of three still photos from the Chevrolet Engine Production Line that I down loaded from a Jam Handy film. Not color, but we know it was gray and the shade is definitely not light gray. The first picture is the one Lonnie used on his Photobucket page of his painting session: http://www.pbase.com/dennygraham/image/159127645 This is right after the 216 was painted for my ’50, it’s definitely not light gray: http://www.pbase.com/dennygraham/image/160216333 In fact, to put it in a little better light here's a black and white for comparison: http://www.pbase.com/dennygraham/image/160755287 dg
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | You definitely see the contrast between the black dist cap and the engine. And the white shirt. Also the man standing near an engine appears to have light gray pants and the frames the engines appear to be the same gray as well. The contrast/color in the B&W photos (colors shown as different shades of gray) makes it look as your engine and those engines are of very similar color. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | It's pretty, but if there is no blue in the second picture, I have other problems. As a commercial print shop owner, I am very well aware of mixing all shades of gray and you should never see anything but black and white in any shade of gray. In the engine photos back from the day, the black distributor cap is very telling. The color they used is right in between black and medium gray. But its like someone else said earlier, they didn't have controls on that color that were all that meaningful because I have seen stock engines in various different shades. It reminds me of the very same dilemma we have with interior colors. Be happy with your choice and move on I guess. For our original poster, you can get pints, quarts and aerosol from The Filling Station if you like dark blue-gray, or a little milder gray-gray from Bill Hirsch in pints, quarts, and aerosol. That is what I would take away from this. The idea in the first place was a machinist gray I am sure. All of the engines here are painted with Bill Hirsch... http://devestechnet.com/Home/MorePix#enginepicsOne could argue you see blue in them too, but like I said before it matters what your shop lighting is like when you take the picture, or how hard your cameras flash bounces off the paint. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | What really counts is what makes you feel good when you raise the hood, whether it was that way when it came from the factory or not, ya see.....it really makes no real difference if that's what pleases you. Some feel light gray is nice some like charcoal gray some like Ford gray or blue gray. Heck Orange & Black even looks good to some? Each to his own, as long as you're getting some pleasure out of you Stovebolt.
dg
d
| | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | My 235 is Chevy orange, and I like it.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | My 235 is Chevy orange, and I like it.   | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....just my take. After 37 years of printing/finishing/dyeing and of trying to please some stylist on a shade she THINKS she wants call the grey/gray anything you want! For me, I've chose the Plasti-Kote Universal Gray. It says on the can its an OEM color. Denny, you know how I am...so I called Plasti-Kote and ask them WHAT AND WHICH OEM color was it. After about 5 minutes on hold the guy comes back and tells me its and "average" of the OEM gray's at the time...but couldn't or didn't tell me what the "time" was. As suggested, I like the #202 Universal Gray from Plasti kote and going to argue with any Friday night cruiser that says its not the original color. Now, take that  | | | | | Joined: May 2014 Posts: 75 'Bolter | | 'Bolter Joined: May 2014 Posts: 75 | Wow I didn't think I would open up such a hotly debated subject! I really appreciate everyone's opinions. As many said, if it pleases/looks good to the truck owner...well that's all that really matters. I will continue to use the Duplicolor New Ford Grey as that's what I started with and it looks good to me. If I need to do any touch ups, I'll spray some of it into the cap and then brush it on. The consensus seems to be that engine paint is different than "body" paint and that makes sense. So again, thanks everyone for your replies. Brad. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | This happen every time
Part of stovebolt folklore
Same thing happens with Pertronix | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yeah, anytime things get dull around here all ya gotta do is bring out the color charts. Now Brad, how bout you ask about the interior colors???? That orta keep thing lively thru the weekend.
dg
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | At least we have codes to argue over (and to confuse us) for the interior colors. | | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | Deve, I recently layed my eyes on an original 55.2 with the original 235 in it. It still has remnants of the yellow 235 lettering on the valve cover. It was completely covered in the typical dirty oil grunge. As we cleaned off the grunge, the lighter gray paint started to show through. It looked remarkably similar to the medium gray in your pictures, but not similar to the grungy dirty oil film, which matches the paint on the three original 216's I have seen in person. Do you have pictures of any original 216s with medium gray paint similar to what you are using? Carl
| | | | | Joined: Jan 2014 Posts: 3,677 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,677 | Yeah, anytime things get dull around here all ya gotta do is bring out the color charts. Now Brad, how bout you ask about the interior colors???? That orta keep thing lively thru the weekend.
dg I was kinda thinking it was time for another engine oil debate.
1951 3100
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I do not have original pictures of any of our engines Carl. As a parts picker for Jim Carter for a few years, I saw MANY of these engines all over Kansas, Oklahoma and Missouri while in countless salvage yards. All the 216's and 235's were medium gray until 1955, then you would see blue, black, orange, sometimes medium gray but they were all over the place.
I know the VCCA fellow said Blue Gray but I would beg to differ. I chose the Bill Hirsch color because it was THE color I saw consistently in the salvage yards under all conditions. Cloudy, Sunny and all months of the year, the color was consistent with what we pulled out of original trucks. I am happy with my choice and apparently that's about as good as it gets! | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It never ends.
Any truck that was put to rest in a "salvage yard" most likely had it engine rebuilt at least once and most likely several times. "Evidence" from a salvage yard is very suspect. | | | | | Joined: May 2015 Posts: 236 Shop Shark | | Shop Shark Joined: May 2015 Posts: 236 | One would think that Gray is just a mix of Black and White. But this is not true for many paint applications. As it is a very flat range of gray. Many paint companies mix Gray with out Black some use left over colors of several batches to mix shade or tones of Gray.
Chevrolet may have been in the mode of mixing the engine Gray from leftovers.
But even if not it is very common to have a bit of Blue tint in a gray paint mix to bring up the tone.
If this might be so for the Chevrolet engine Gray even if a very slight amount to some in the right light it would appear with a slight blueish affect. The one original engine I have seen to me while it is Gray does have a slight Blueish tinge with age and fading from time and washing whether or not this was stronger 60 years back I could not say.
I would prefer a not Black/White mix but more the very slight tinge of Blue effect in my Gray to stand out to the right eye. But I do not want a Blue engine.
Baking in the nice desert sun, breathing life back into a 48 3800 5 window. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | One salvage yard yes Tim.. Hundreds, pulling engines in each one from every year since the 30's, you get to see the similarities, what has been repainted and what hasn't. We tore lots of these engines down for the manifolds, carbs, flywheels, etc, etc. So no, I am absolutely convinced the color I am using is correct to the very most minute detail. I do not worry about what everyone else thinks because I saw this with my own eyes.
Gray IS an absolute mix of black and white. As someone who mixes printers ink regularly I know, however, Black is a mix of what? White is a mix of what? So.. you are correct.. I really don't think Chevy had controls on the mixing process, or they were too wide. Meanwhile, I didn't see much difference in the salvage yards until 1955. Oil and dirt sandblasting the engine paint, then heat cycles would have a lot of affect. BUT.. not in places where none of this occurs. Behind the starter, fuel pump, etc, lots of places where I was able to actually see the colors. Some of these salvage yards had very nice trucks in them. Now those parts are on other people trucks!
And, Arizona, there IS a very slight blue tinge to Bill Hirsch but not unless you are looking for it. Check the link I mentioned earlier to see what Bill Hirsch paint looks like. I know what I know! LOL! | | |
