8 members (78buckshot, Woodcmiami, cmayna, Hotrod Lincoln, Gdads51, mick53, MickeyP, 1 invisible),
38
10
Mod | | | Forums66 Topics128,012 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 38 New Guy | | New Guy Joined: Jan 2002 Posts: 38 | Hey Guys,
I have a 46 gmc 1/2 ton. I am starting restoration on my cab, I just noticed that the rain gutter has rust between it and the cab and the rust is starting to spread the two apart.
Has anyone fixed this problem?
What is the best approach.
I was going to remove the rain gutters and clean all the rust, but is there an easier way?
Also, what's the best way to remove the rain gutter?
Brian
"So many trucks, so little time!"
Vehicle list: down to 2 now. 1 - 1967 Chevy 3/4 ton LWB 4x4 2 - do I dare say it??? a 61 Ford Unibody | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | on my 37 they were so bad I took them off. I found some late models, with the chrome trim, has just about the same "curve" and would look great and work good. check out a few trucks at a good used truck lot to see if you can replace yours with a nice shiny one  | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | how about with the task force series? (55-59) I looked inside mine and I think the back of the cab leaks at the rain gutter for perhaps water getting into the cab? It looks like the rain gutter is stamped into the shape of the sheet metal, so this might be a good time to just clear it off and bondoglass that bit to seal it (not like you could see it bondo'ed as the truck is so tall) | | |
