8 members (68ironhead, jmoore, Joe H, Phak1, 55shaker, 3B, Waveski, 1 invisible),
74
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,834 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 91 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 91 | Finally got some bedwood. This is recycled Southern Yellow Pine. Got it at a building materials recycle place. They are old bleacher seats. Worked out good, the holes in them were fare enough apart to cut them off and have a clear board wide enough to do what I needed. Very reasonable, $1 per linial foot, bought enough to have a little extra in case I screwed up cuting width, groves ect. Was able to sand them to get most the crud off then ran them through the planer, cut the groves to Mar-k instructions with a table saw and router, finished with 3 coats of marine grade polyurathane. Total cost for wood and finish about $120 plus a fair amount of time, don't have it bolted down yet but thought it looks good and wanted to share. Look here: http://s1148.photobucket.com/user/1...amp;_suid=143605202708905001775288012367 | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Wow, that's beautiful! It looks like heart pine with a great patina. | | | | | Joined: Jun 2012 Posts: 91 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 91 | Wow, that's beautiful! It looks like heart pine with a great patina. I did put a dark walnut stain on it. | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | Looking for salvaged SYP, especially if it comes from an era when there was such a thing as old growth pine, is a great idea. The old growth pine has a very tight grain caused by very slow growth rate. This makes for a more dense and harder material. SYP grown today is managed in such a way as to get a tree to grow large as quickly as they can, resulting in the opposite affect. Carl
| | | | | Joined: Mar 2014 Posts: 4,504 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,504 | If you can find an old house being demolished, ask if you can be allowed to get some of the joists, rafters, etc. Especially the ones in the attic. They'll likely be SYP and as hard as iron. Some may have knots but some may be clear. Jon
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Very nice Plowboy.............the walnut stain really brought out the grain...... you plan on hauling firewood in that bed....lol Dan | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | And .....that dually stance looks great from the rear..Great job!!! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Ditto what the others said. Nice! | | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Plowboy, Did you stain first then use your 3 coats of polyurethane? I would like to do what you did to my 1 ton. Thanks By the way, that dually is very sweet! Fox J
| | | | | Joined: Jun 2012 Posts: 91 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 91 | Plowboy, Did you stain first then use your 3 coats of polyurethane? I would like to do what you did to my 1 ton. Thanks By the way, that dually is very sweet! Fox J Yes apply stain first, how long you let it set before wiping it of will have a impact on how dark it is. Let the stain dry about 24 hrs and then clearcoat, sanding with 320 grit between coats. (Barrow your wifes fuzzy vacume attachment to clean up sanding dust) | | | | | Joined: Mar 2010 Posts: 10,298 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,298 | Might be a better idea to borrow your buddy's wife's attachment.
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | | | | | | Joined: Sep 2011 Posts: 2,951 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 2,951 | I read this thread and then went to the local lumber store a few days later. I was pleased to find some SYP at a price I could afford. However, simple things became a bit complicated. Read the July 12th entry of my BLOG for the full story. I will not a have a beautiful bed like the one pictured in this thread. The 1965 beds were dark black - more of a charcoal black with black strips. I plan to do mine that way. | | | | | Joined: Oct 2015 Posts: 11 New Guy | | New Guy Joined: Oct 2015 Posts: 11 | Plowboy,
Do you have any side shots of your truck? I'm building a 48 Coe, going on a dodge 3500 donor. I'm wanting build a bed and curious see how yours looks over the duals.
Very sweet bed and likes the dually appearance from the rear..
Thanks, Chance | | | | | Joined: Jun 2012 Posts: 91 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 91 | Added photo's with wheel wells installed. http://s1148.photobucket.com/user/1Plowboy/library/?sort=3&start=&page=1 The first one is a overhead shot of inner wheel well, bedside and outer fender. The bed is about 6 inches wider than a stock bed, see that in the second photo. I did this so the stock outer fender covers the outside dual and the wheelwell on the inside covers the inner dual. Wheelwells are 60-66 repop's with 3 1/2 inches cut from the width. The bed has a bend just in front of the fender to bring the width at the front back to stock so that it meets the back of the cab where a stock bed would. Hope this helps
| | | | | Joined: Apr 2002 Posts: 2,168 A teacher, but always an apprentice. | | A teacher, but always an apprentice. Joined: Apr 2002 Posts: 2,168 | Plowboy, your truck is sure comin along nicely! I love the presence your truck has! Chance, Here's what I did with my 1 ton for my dually. I made a fender extender a built a custom running board. My bed is stock dimensions otherwise, and if I want to return it to single wheel I just remove the board and extender and viola back to stock. This may not work on your big bolt COE though. http://s1372.photobucket.com/user/f...age_zpsurdhwhiq.jpg.html?sort=3&o=10 | | |
