0 members (), 103 guests, and 2 robots.
Topics128,093
Posts1,056,474
Members48,444
We replaced the stock tranny in my 1949 GMC 1/2T 4-on-the-floor pickup with a SM420 matched to a newer 270 engine. It sticks up about 2 inches above the floorboards, so we can't cover it with the original flat piece. I could modify a fiberglass repro, but 'bolter CMAYNA who put a backup light switch on the same tranny says he has a humped metal cover that fits. He says it has what looks like a handbrake slot next to the hump, and he thinks it may have come out of a 1-ton.
Any ideas where to get this kind of humped cover?
Never start vast projects with half vast ideas.
I used a 13"X 9" cake pan as the hump when I rebuilt my trans cover pan. Looks almost identical to the original,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
1 Offline
Quote
Scott
now that is some ingenuity if i have ever seen it. probably the cheapest option too.
2003 ford lightning
1959 chevy 36
Well, the SM420 was original equipment in a lot of 3/4 ton trucks, and most of those came with a floor brake, so you should be able to find one. I have one but I'm not letting go of it.
Paint & Body Shop moderator
Thanks. Nice to know what to look for and using the cake pan is a great idea.
Here's a picture that kinda shows what it looks like. Hope it is what you're looking for,
Scott
[img]http://img116.exs.cx/img116/6774/im0009568pi.jpg[/img]
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
