| | | Forums66 Topics128,100 Posts1,056,514 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 100 Member | | Member Joined: Sep 2001 Posts: 100 | We replaced the stock tranny in my 1949 GMC 1/2T 4-on-the-floor pickup with a SM420 matched to a newer 270 engine. It sticks up about 2 inches above the floorboards, so we can't cover it with the original flat piece. I could modify a fiberglass repro, but 'bolter CMAYNA who put a backup light switch on the same tranny says he has a humped metal cover that fits. He says it has what looks like a handbrake slot next to the hump, and he thinks it may have come out of a 1-ton. Any ideas where to get this kind of humped cover?
Never start vast projects with half vast ideas.
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I used a 13"X 9" cake pan as the hump when I rebuilt my trans cover pan. Looks almost identical to the original, Scott | | | | | Joined: Sep 2004 Posts: 148 Member | | Member Joined: Sep 2004 Posts: 148 | Originally posted by 48bigtrucks: I used a 13"X 9" cake pan as the hump when I rebuilt my trans cover pan. Looks almost identical to the original, Scott now that is some ingenuity if i have ever seen it. probably the cheapest option too.
2003 ford lightning 1959 chevy 36
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Well, the SM420 was original equipment in a lot of 3/4 ton trucks, and most of those came with a floor brake, so you should be able to find one. I have one but I'm not letting go of it.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Sep 2001 Posts: 100 Member | | Member Joined: Sep 2001 Posts: 100 | Thanks. Nice to know what to look for and using the cake pan is a great idea.
