7 members (SWEET, Donf, rfs56trk, sron48, 78buckshot, Wickedbass, JW51), 60 guests, and 1 robot.
Topics128,023
Posts1,055,367
Members48,420
#1110168 06/25/2015 9:52 PM
So what would be a good radiator for this build?
Thanks,Pete
Pete52 #1110175 06/25/2015 10:37 PM
For what build? What are the details of your truck?
My 46 GMC on Photobucket
Pete52 #1110194 06/26/2015 12:43 AM
52 1/2 ton installing a 400 cu.in. mopar BB with 727 trans and ford 9 inch rear.
Pete
Pete52 #1110195 06/26/2015 12:44 AM
Gas Pumper
Gas Pumper
If its a 52 3100, US Radiator makes a really nice original looking radiator only using a more modern 4 row core. They are pricey at about $600, but it opens the door for AC or anything you want to hang on it, while enjoying the benefits of the stock look.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Pete52 #1110234 06/26/2015 3:31 AM
Pete, you may want to check in with Dillion Radiator? Or Champion Cooling which is who makes them for Dillion.
Pete52 #1110271 06/26/2015 12:45 PM
Thanks,I'll look into it today and see.
Pete
Pete52 #1110281 06/26/2015 2:37 PM
I found my 4 row aluminum on evil bay at just $200. It mounts in the stock location using the stock bolt pattern. Job took a whole 20 minutes and it cools the 350 just fine.
Yep! Me too. It looks like a Harrison brass one after you paint it black.
Carl
Pete52 #1110405 06/27/2015 1:18 PM
Do you remember who made it?Or where you bought it from?
Pete
Pete52 #1110406 06/27/2015 1:27 PM
Sorry Pete I do not. I went to evil bay and did a search for aluminum radiators then found the 4 row one and went to their on-line store and searched their catalog until I found the ones fitting our AD trucks and clicked the purchase button. Easy process, I think you will do OK. Good luck.
