2 members (Peggy M, panic),
89
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | So what would be a good radiator for this build?
Thanks,Pete | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | For what build? What are the details of your truck? | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | 52 1/2 ton installing a 400 cu.in. mopar BB with 727 trans and ford 9 inch rear.
Pete | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | If its a 52 3100, US Radiator makes a really nice original looking radiator only using a more modern 4 row core. They are pricey at about $600, but it opens the door for AC or anything you want to hang on it, while enjoying the benefits of the stock look. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Pete, you may want to check in with Dillion Radiator? Or Champion Cooling which is who makes them for Dillion.
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Thanks,I'll look into it today and see.
Pete | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | I found my 4 row aluminum on evil bay at just $200. It mounts in the stock location using the stock bolt pattern. Job took a whole 20 minutes and it cools the 350 just fine.
| | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | I found my 4 row aluminum on evil bay at just $200. It mounts in the stock location using the stock bolt pattern. Job took a whole 20 minutes and it cools the 350 just fine. Yep! Me too. It looks like a Harrison brass one after you paint it black. Carl
| | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Do you remember who made it?Or where you bought it from?
Pete
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Sorry Pete I do not. I went to evil bay and did a search for aluminum radiators then found the 4 row one and went to their on-line store and searched their catalog until I found the ones fitting our AD trucks and clicked the purchase button. Easy process, I think you will do OK. Good luck.
