2 members (Hanks custodian, ShopRag), 115 guests, and 2 robots.
Topics128,049
Posts1,055,677
#1109126 06/20/2015 1:30 AM
I am in the short rows of finishing up my custom 53. I have installed the seal in the windlace. I have the outer seal and I think I want to use it. Couple of questions. First....I don't recall ever seeing this seal on any trucks at shows etc. Do people often just leave these seals off or did I just not notice them?? Second... several years ago there was a very good post on Stovebolt showing the correct way to install these seals....can't find it....please help. sojo
Sojo #1109156 06/20/2015 4:28 AM
There's a great you tube video on this. I think thefillingstation.com sponsors it. Just search YouTube for Chevy truck weather seal.
NHluvstruck...
1951 3100 5-window
https://stonefacegarage.wixsite.com/mysite
51 Chevy Restoration Page
Sojo #1109201 06/20/2015 3:56 PM
I just did this twice following the filling station instructions. I did it the first time and the doors would not close. After much research I found that there are two thickness for these seals. Most of the vendors sell the thick stuff, the affordable stuff. Ordered the thinner stuff, from the filling station, pulled the doors off, stripped the molding, cleaned the glue off, and glue the thin stuff on. My suggestion tape on a couple small pieces in key spots and see if the door will function before gluing it on. Just saying.
Sojo #1109228 06/20/2015 8:20 PM
I also put seals on the doors of my '55 1st series. Used the thicker seal and had problems closing the door. Odered the thinner seals and the doors are sealed and close great. I suggest removing the doors and prior to that, drill 1/8 diameter holes thru the door and each hinge. When installing the doors use couple 1/8 diameter pins to align the doors and then install the hinge bolts, That worked for me.
Sojo #1109406 06/22/2015 12:03 AM
Thanks to all.....I found the video...it was what I had seen before. I have determined that my application requires the thick seal which is what I have...thanks again. sojo wave
Moderated by  ndkid275, Phak1
