| | | Forums66 Topics128,080 Posts1,056,315 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 127 | I'M BACK AFTER YEARS OF BEING AWAY!!!! I now have the money to restore my truck!!
Anyways - Which sandblaster/media blaster is the best? I'm going to be buying a new compressor as well, but want to know about the sandblaster. I know nothing about these. Any advice? Particular brands? I want to save money where I can. I want a descent one, but nothing expensive! Thanks in advance!!
1952 Chevy 5 Window Restoration
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Expensive is a relative term. It gets even more relative when you consider the pain you go through going too cheap. I started with a $39.95 Sears Siphon blaster. Wow! I wouldn't want to go through that again! Here is all the wisdumb I have accumulated over the years on this. If its an inside the shop media blaster, TP Tools is THE go-to resource. http://devestechnet.com/Home/SandBlasting | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | TP TOOLS.... nice cabinet, not the biggest, but you can expect to pay around 1200 for one with the vac system. I've had my cabinet for about 14 years. Its great. Be sure to get at least a compressor that is a two stage 175psi with around 17-19cfm at 90 psi and an 80gal tank. Others will have a lot more input than me but this is what I feel is the least to go with if you do much blasting at all. My compressor, like the one describe above, runs a lot but will "catch up" on continuous blasting. Do it once....do it right. | | |
