Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 37 guests, and 5 robots.
Topics128,009
Posts1,055,293
Members48,419
#1107786 06/11/2015 11:56 PM
Installed front disc brake set on my 52 hotrod build what master cly is a good choice also have ford 9 inch with 2.5 X 11 inch drums in the rear.Do I need residual valves? I would like not to have power just have manual brakes.
Thanks,Pete
Pete52 #1107794 06/12/2015 12:41 AM
Pete, I know some guys who do NOT run them and some that do. I've never heard either of them complain.
I think PirateJack.net recommends a 10 lb residual for the rear and a 2lb for the front running the set up you have.
I am running all drum on my panel but I still put a 10lb residual on the line to the rear. Its suppose to help overcome the springs tension as it keeps some pressure there. I have not had any problems in 2 years and I can stop the panel on a dime and give you 9 cent change!
(Is the steering box going to work for you?)
Pete52 #1107845 06/12/2015 12:26 PM
Box is mounted,Thanks.Been trying to figure out what master to use.
Pete
Pete52 #1107879 06/12/2015 3:37 PM
Hey Pete
I am dumb as dirt when it comes to this stuff but I went to a pre-engineered package I got from Classic car and Performance (CPP) out of the left coast...
http://www.classicperform.com/Store/1947_59_Trucks/4954CBK-6HK.htm
Here is the link to the kit I bought...quality seems ok...roller bears are Chinese tho..I have not run my truck yet but it was basically a bolt in deal...I am good wrench turner but not a good thinker of new thoughts...saves way more time and problems if you buy these kits...guys on the phones seem pretty decent too..
My smelly old 2 cents...
MikeC
1951 Chevy 3800 1-Ton
Howard Knapp
