1 members (SandraD),
56
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 60 | my 54 engine is stuck. Looked at the valve lifters and they are all stuck (looks like un run rebuilt with moisture) is there any easy way to remove them from the block without removing block and or cam? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I think I would pull the block. If it is that bad...it is that bad everywhere. Get some KROIL. It works better than anything to help unstick engines. | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Propane torch- - - -Kroil- - - -torch- - - -Kroil, etc. You won't get the lifters hot enough to damage them and the block will absorb much more heat than any small torch can produce. After several heat/oil cycles, use vise grips to wiggle the lifters around.
Definitely do a full teardown- - - -you're going to find rust everywhere. Jerry
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Bill, it isn't what you want to hear, but if the lifters are rusted to the block, imagine the pistons, cam, rocker assembly, valves, etc. Even if you have the very best of luck and you get it running, it wont run very well for very long. Plan on a full teardown and rebuild. Its a few grand to get the machine work done, but you wouldn't hesitate to spend that on your newer driver, and it's well worth the peace of mind. Jerry knows. The problem with the 54, the valve cover has slots in it that allow air, dirt, water, etc to enter the engine. If it wasn't properly covered, it needs a full rebuild. Do IT and yourself a favor and just tear the whole thing down. Don't force anything and treat it very delicately. Once you have done it right, you won't be able to wipe the smile off your face! Find a good engine machine shop, check out this article so it helps you understand what you are up against.. http://devestechnet.com/Home/Project1959235It isn't as daunting as it looks. Holler if you have questions, We are here to help. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Listen to what the guys are telling you. Have an "un-run" rebuilt 261 that had 5 stuck lifters and a bad #2 rod bearing. Pulled head and kept going. Pulled engine, rods and everything else covered with a light brownish rust. Did a full tear down, cleaned everything up including a couple new rod bearings and all is now well. Ready to put it in and fire it up......and yes, the engine was sealed up to the point I thought it was pretty good...yeah right! | | |
