1 members (klhansen),
140
Mod | | | Forums66 Topics128,131 Posts1,056,727 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | I want to insulate this area and I'm not sure of the correct procedure for removing the "panel". Are there special tools that I will need? Steve | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Can't think of any special tools. There is not much room in there to work so I used 6" wide sections and dropped them down into the door and then stuck them the best I could. Depends on what you use as to how it sticks to the inside of the door. Pull the panels and have at it. Nothing to it! | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | If you pull the window you can drop full width x 18" or 20" sheets. 1/2" foam with the Al backing works well too.
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | CASO how do you pull the window? | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 |
| | | | | Joined: Aug 2011 Posts: 815 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 815 | | | | | | Joined: Feb 2011 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 38 | When you say "pull the panels and have at it", I don't understand what panels you are talking about. | | |
