7 members (55shaker, Jeff Ogden, RoadsScholar, Gray_Ghost, Ponchogl, fonz8261, 1 invisible), 82 guests, and 1 robot.
Topics128,131
Posts1,056,722
Members48,454
#1106109 06/02/2015 4:52 PM
I want to insulate this area and I'm not sure of the correct procedure for removing the "panel". Are there special tools that I will need? Steve
Can't think of any special tools. There is not much room in there to work so I used 6" wide sections and dropped them down into the door and then stuck them the best I could. Depends on what you use as to how it sticks to the inside of the door. Pull the panels and have at it. Nothing to it!
If you pull the window you can drop full width x 18" or 20" sheets.
1/2" foam with the Al backing works well too.
Give me ambiguity
or give me something else
CASO how do you pull the window?
Here you go.
Give me ambiguity
Thanks CASO
When you say "pull the panels and have at it", I don't understand what panels you are talking about.
