3 members (Peggy M, Pre '68 Dave, 1 invisible),
101
Mod | | | Forums66 Topics128,031 Posts1,055,434 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 148 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 148 | Denny Graham mentioned awhile back that he used a product called ARGO chain and something lube on his leaf springs and he was very happy with the results. His 3600 rode like his new Silverado he said. He got it at a farm implement store. In Tucson I have found the John Deere dealer and I would like to know what you all recommend. Do you pry open between the leafs and spray? I have a 54 3600 with all new suspension parts. Thanks for the help. Sharon | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | No Sharon, just put a cardboard on the floor under the spring and spray the edges inside and out and it will wick in between the leafs. Don't get the "chain" lube which is meant for motorcycle chain. Those products are basically a heavy grease and when the solvents evaporate it will leave a sticky mess on the springs. The "chain & Cable" spray is a light oil that will penetrate in between the leafs. I could not find the Brand (AGCO) that my friend gave me but at any of the big box stores you should be able to find this product which I believe is the same thing. http://www.homedepot.com/p/Blaster-11-oz-B-laster-Chain-and-Cable-Lube-16-CCL/205851095 Point being, this isn't rocket science, it's not the brand, so just about any lubricant that you can get to wick into the spring will work better than nothing. Even mixing any oil that you may have on the shelf with some thinner and applied with a spray bottle I would think is gonna work just fine also. After soaking the springs I wiped the access off of the outside and haven't noticed any thing dripping on the floor. No matter what you use to lub them, it's going to get worked out fairly soon. The teflon/delrin liners are a permanent fix. I never though much about this in the past and was satisfied running leaf springs dry, but as I said before, I'm a convert now. dg
Denny G Sandwich, IL
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Denny, This is good timing for me because I've got my springs apart for glass beading, cleaning and a light coat of paint. Have you noticed this lubricant attracting dirt into the springs? Thanks, Steve 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | FYI, In the early days of the automobile, some manufactures coated all the leafs in grease and wrapped the whole assembly in cloth to keep the grease in/dirt out. The springs had a shorter life than dry springs and the practice was stopped. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | It is recommended to not blast steel spring leaves because of stress risers.
I got some graphite paint to spray between leaves, comes in quarts or spray cans(handy).
Google 'graphite paint.'
| | | | | Joined: Jun 2013 Posts: 148 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 148 | Denny thanks so much for your great reply. I will start looking for the lube. Sharon | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Why not just spray the leaf springs with Liquid Wrench penetrating oil or WD 40? | | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | It is recommended to not blast steel spring leaves because of stress risers. Glass beading will reduce stress risers. Compresses the surface of the metal. The beads fracture before reaching the pressure that removes more than the rust on the surface. Denny, This is good timing for me because I've got my springs apart for glass beading, cleaning and a light coat of paint. Thanks, Steve Steve - I would recommend applying two coats of POR-15. It has excellent abrasion resistance and has a slick surface. Should work without having to lubricate the springs.
Fred 52 3600 69 C-10
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Steve, I’m sure that any lubricant, even the lightest oil is going to attract dirt. Over the years that has been one of the reasons I’ve been running them dry. I think one has to consider the life expectancy of a set of springs. Most of us tend to think that they will go on forever, but the reality of it is that any metal part that is constantly being flexed is eventually going to fatigue and fail. So….I suppose your question is, how much are we reducing the life of the spring by attracting dirt to it? I don’t know, maybe someone else has done the calculation.
Where did you get that information from Jim? I personally find it hard to believe that would shorten the life of the spring. It does seem logical that they would have ended the practice because of the expense. Although lubrication does improve the ride, a dry spring will perform just fine without it.
Liquid Wrench and WD-40 are basically solvent such as kerosene, with a very, very small amount of oil. Spray either one on something and come back the next morning and it’s probably going to appear dry. The Chain and Cable lube or lube or motorcycle chain has a lot more of the oil or grease that you want to get into the machine.
According to Eaton Detroit Spring, you shouldn’t paint or powder coat ‘between’ the leafs. That makes sense to me, because as it works out from between the leafs the pack will become loose.
There are as many opinions on restoration and maintenance of leaf springs as there are people who use them. I’m just reporting the results that I’ve had and what I’ve recently discovered. Arguing my way is the right way is as useless as arguing Religion, Politics or which make car is the best.
dg
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Wealth of info here. Thanks all for sharing on this subject. I might end up condemning my front springs. Seems they were in there a little to long and the pivot bolt sleeves were worn plumb through and egg shaped the spring eye. Great thread. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Feb 2000 Posts: 5,195 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,195 | When I rebuilt my springs the first time, I used a grinder to clean up each leaf. My truck came from the Kansas's Flint hills area and was run really hard. The lower leafs dug into the ones above creating steps. These steps kept them from moving. I rounded over the edges so everything had a place to move. Before assembling, I greased each leaf with a heavy teflon, sticky grease that wouldn't run or drip no matter how hot it got. About a year later I decided to remove a couple of leafs from each pack so a I tore them apart. I was surprised to find rust back at each contact point in the pack. The grease was pushed out over time and they were back to being dry.
I then installed teflon liner under each leaf from front to back, it was a night and day difference in ride. All the banging and noise was gone, the harsh bumps were smoother out, and long trips no longer wear me down.
When I replaced the front springs, I tore them apart and added the liners before installing them. The stuff I bought is black with small sides to keep it in place. It's been there ten or more years now. A spring shop can punch holes in the ends so you can add the teflon buttons if you don't want the liners. I tried to drill mine but didn't have a bit strong enough to touch them.
Joe | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I did not get to ride in my panel before I took the springs apart so I really can't compare. However, I used the Teflon liners. The ones Joe describes sounds just like mine. I can attest to the fact that even though the panel is big, tall and heavy it does ride pretty doggone good. I drove it to get BBQ today and my friend rode with me and commented on how well it rode. Maybe its the iners??? maybe not?? It must ride decent though. Victoria rode with me in it to the Reunion in Kansas City and never complained about the ride!!!
My vote is... I like the liners. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Who says you can't teach and old dog......! I'm pretty sure I've become a convert thanks to the ride me and Bruce took last week. He talked me into juicing up the leaves with the cable lube. Like Joe posted, even a heavy grease will work out at the contact points of the leaf pack. I'm anticipating giving mine a squirt every couple of weeks, which is gonna get old before summer is over for sure. So....I'm pretty sure now that I'm gonna opt for a set of liners when I finally get the nerve up to pull the rest of the truck off the frame for the full restoration. Teflon seems to be the buzz word whenever I skim through discussions about leaf springs. But Mike Eaton seems to have a little different take on what material is best. He can say it much better than I can so I'll shut my yap and link ya to it, that is, if you care to see another take on the subject: http://www.eatondetroitspring.com/leaflubricantleaflinerstipinserts/dg
| | | | | Joined: Mar 2014 Posts: 4,479 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,479 | Liquid Wrench and WD-40 are basically solvent such as kerosene, with a very, very small amount of oil. dg Hi Denny, In my opinion, the degree of precision in jeweled watch movements is pretty close to magic. Oil used in mechanical watches is a matter of endless and occasionally manic debate. Around 20 years ago a friend who also repairs watches and I were talking and he told me if I wanted a great alternative to expensive oil just shake the WD40 can really well for a few minutes and spray an inch or so into a pimiento jar or other small glass jar. Let this sit undisturbed for a week and you'll see 2 layers. At the bottom will be a cloudy whitish layer containing paraffin and other trash (possibly even some water for all we know) and at the top will be what you want...a very fine oil mixed with a petroleum byproduct of some variety. Don't know what it is but it floats in this mixture. When it dries, it will have just the amount of lubrication you need. I've used it in watches, sewing machines, typewriters, electric motors, cameras...all sorts of things. And it works just like he said it would. Just keep away from the bottom layer. Now, for the flip side: Since then I've watched all sorts of people use WD40. In fact, every time I see anyone pick up a can of WD40, I stop and watch them. Male, female, young, old, smart, not so smart. It doesn't matter. Most of them simply pick the can up and start spraying immediately, occasionally comically jiggling the can a bit as they spray. I'll bet you've seen people do this, too. If not, please start watching. Remember what is at the bottom of the jar? Well, this comes out first unless you shake the can and it will until that bottom layer has all been sprayed out. But I can't believe the WD40 people want that to happen. Jon
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I shake all the spray cans I use whether it's paint or oil or grease or whatever. The only way to get anything to come out in a spray is by liberal use of thinners. That's the prime reason rattle can spray paint gets its bad name, it's thin and doesn't cover like canned paints. Restoring old radios and vintage test equipment held my interest for many years and when the need for a fine lubricant came up I use Turbine oil. It's highly refined and will not dry out over time. Chevron and others make it for commercial use and it's used a lot in aviation also. The stuff that I've been using for years is Norvey Turbine oil. Works great for instrument jewels, small motor and air tool bearings. Wouldn't recommend it for leaf springs at about $6 an ounce.
dg
| | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | WD40 is great for cleaning. It also shines up my old 47 truck. I believe one of the main ingredients is fish oil. Who cares, not using it for high end lube. Anyone like Triflow?? I do.
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | But you don't want it in places like a speedo jewel or cable because of the Teflon. Probably work just great in a leaf spring, at least for a little while. Still it's about a buck an ounce most places. http://www.pbase.com/dennygraham/image/160199883/largedg
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | From Eaton's website: "Using graphite between the leaves would certainly reduce friction without harming the steel like grease does."
I got a "oops" message on their tutorial links, but how does grease harm steel? I can see the grime collecting & making a rubbing compound- is this the harm?
This "harm " must be mechanical (over chemical).
Brad Wrench Fetcher, PhD | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | No one has been able to figure that one out Brad. Why don't you post that question to Mike Eaton on his forum and see if he can be more specific about it, maybe even steer you to some documentation. According to what I get from his statement, the grease chemically reacts with 5160 alloy. His test is that heavy trucks that leak steering gear fluid onto front springs cause the springs to eventually fail. But.....I've not been able to verify that from any other source. If that were true you would think that one of the metallurgical sites would have discussed that phenomenon at sometime. And graphite would certainly reduce the friction but just like grease, oil, Teflon or any other dust or loose fiber suspended in a fluid, it wouldn't stay between the leafs for very long. A least not where the leafs were in contact with each other where they moved. That was the reasoning behind the wrapped springs years ago, that is, the retention of the lubricant.
dg
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Purpose(s) of spring-wraps/gaiters: speculation from H.A.M.B.ers My speculation is: - to keep the lubricant in, and - to keep the dirt out, and - to look nice (an all-in-one wrapping) | | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Back in the 50's, we were distributors for Conoco and we got a new Chek Chart Lubrication manuals every year. I still remember the recommendation was lubricate passenger car springs to maintain a smooth, but to leave commercial truck springs dry because the springs required the the friction. Until we phased out springs in favor of air ride over 30 years, we never oiled springs and service manuals warned against it. In those days trucks leaked a lot of oil, and oily springs broke. It was particularly dangerous on the steering axle because the wrap leaf didn't always hold it. Trailer suspensions have torque rods to keep the axle in place.
I still have 9 dry vans on spring ride and steering axles are still spring ride. DOT regulations tolerate zero oil leaks. I don't remember when we last broke a spring. | | |
