2 members (cmayna, CuzzFuzz),
60
7
Mod | | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 148 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 148 | got a set of mirrors for my 49 1/2 ton. Is there any way to measure where to put these things. Sure hate to drill more holes than necessary. The mirrors I got are supposed to be like the original. Thanks for any help. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I installed mine when the truck was apart
under the dash is a bracket with 4 holes
I matched the two that corresponded with the mirror I used and used a spring loaded center punch from the inside.
then drilled from the outside using the dimple as a guide.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | here is a good pictured of the bracket from denny grahams web site ..dennys link... | | | | | Joined: Jan 2015 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2015 Posts: 34 | Brad, could you possibly give some dimensions? I would try to print your picture and then re-size it using your dimensions.
1952 Chevy 3100
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Here is the right side, passenger mirror mounted in the factory holes with the glove box out on a '50: http://www.pbase.com/dennygraham/image/160139046dg
Denny G Sandwich, IL
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Its easier to drill from the inside through holes already in the support brackets inside the cab. I used a 3 foot long Harbor Freight drill bit to clear the steering mast. You don't absolutely need it, but it sure made it easier. Carl
| | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | Center punch from the inside through the support plate ( already has holes in it) then re-center punch from the outside on your created dimples. That easy! Have to take the glove box out though.
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Carl,
Is that the flexible-shaft bit that regularly goes on-sale for $5.00?
That bit might not be manufactured in China. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Absolutely agree with Gus and Bruce right down to every detail. I used a transfer punch sized to the pre-punched factory hole from the inside, then picked up the dimple outside to drill my hole. Came out perfect on both sides. Using a paper template leaves to much room for mistake in my book. dg
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I can only speak to the factory template I posted (card stock) but it is dead on, I used it for both sides as I plugged the original DS due to damage from a loose mirror and PS because it never had one originally. I try to avoid any interaction with the underside of an AD dash. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Glad that worked out for you Brad, how you find that NOS stuff is a source of constant amazement to me. I'm sure the templates did the job for hundreds of thousands of accessory installers at the Chevy dealerships back in the day also. But finding an original template to most of us today would be akin to finding a fart in a wind storm. I wouldn't trust any reproductions template, if you know what I mean. So picking up the holes from the inside would work the best for 99% of the cases. DG
dg
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | I am going to drill holes for 5 mirrors tomorrow (two left side and three right side to complete fleet). I am going to try the automatic center punch method. I am a lot older, rounder, and everything hurts more than the last time I drilled them from the inside. Carl
