1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 319 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 319 | '59 235 with stomp starter
It never occurred to me that the stomp button would work with the key in the OFF position, but once I thought about it...sure. That, the fact I have a bad headlight switch (which I'll replace), and the theft issue have me considering a battery cut-off switch.
Have any of you installed one? If so, what type and where? Given the battery and starter location on the far side I'm not picturing anything simple but discreet.
A VW guy trying his hand at a '59 LB fs. Lots to learn, but it's about the journey.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | It will "work" in the sense that the starter turns, motor fires but soon as foot is lifted motor dies because the coil has no juice from it's "run" source: the Ignition "on". They are easy to hotwire, safety switch or not. Use a club on the steering wheel or the gas pedal, hood lock, alarm or don't sweat it. All you have to do to start it is change the wire from foot starter switch-to-coil over to starter hot post-to-coil(or use a jumper wire) and pull the foot lever by hand from under the hood. There are many other ways. You can't "hide" a switch between battery and starter hot. The starting system is too simple to protect. You may find a way to ground the Dizzy or disable the Dizzy but it has one visible wire from coil.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | Lookup "Battery Cut Off Switches" on eBay and there are several options. I use the down and dirty Green switch. It's not particularly hidden but, if they enough about these cars to get around it, consider it stolen anyway. | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | DO NOT BUY A CHEAP BATTERY CUTOFF!
Get one that will carry at least 300 amps- - - -500 is better. This particularly true if you're running a 6 volt electrical system. Most of the inexpensive switches with the red "flag" key are designed for 200 amps or less current capacity. One of those will overheat and/or slow the starter down to the point of doing internal damage to the starter. Jerry
