1 members (Truckrolet),
154
Mod | | | Forums66 Topics128,149 Posts1,056,818 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Is it possible to get a NEW vibration damper ( harmonic balancer ) for the 216 cu.in. Chevrolet truck engine? Can they still be ordered from a GM dealer?
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There are none available from GM. NOS show up on eBay or swap meets now and then. There are companies that rebuild them There are also a lot of good used around also.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Tim, Find the part number (in the Parts Catalog - Old Online Chevy Manuals) and try to search for it here. I do not gamble, but I'd bet is is no longer available from GM. There are, however, a few GM NOS parts vendors with on-line catalogs. I cannot find a URL. A few years ago, I found 50 NOS, GM/GMC-only, big-bolt wheel nuts. I'll look tomorrow (but, I still doubt you'll find one). | | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | Do you necessarily need a balancer with the hand crank lugs?
I have built up a new balancer using a 6" diameter item for a small block V8 and a 2-groove pulley for a big block engine. It requires just a little machining to make the pulley grooves align properly, but the assembly is made up with all new parts. Jerry
| | | | | Joined: Sep 2010 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 49 | You might try Damper Dudes @ 1-800-413-2673 or Damper Dudes. com | | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Sounds like all you need is a replacement for the original? Most Salvage yards in the US have a BatPhone. You as the customer ask for a part, the yard you went to doesn't have it, they put the request out there over the BatPhone and someone answers. It would be a fun journey to the yard anyway! Take a puller made for it to save time! Good luck! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I wonder with rubber the way it ages, whether an NOS damper is a good thing. | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | I have a 235 engine but used as many parts from the 216 as possible, including the 216 damper with the crank lugs on it. I had it rebuilt by the previously mentioned Damper Dudes. They happen to be local and as I walked in the door with my old damper, only halfway to the counter the Dude says Chevy 216. I knew I was in the right place. Finished product was like new. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | $192.39 plus shipping 3/8" or 1/2" groove $228.79 plus shipping double-groove | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That's not to bad. Gettin' bored yet Professor? dg
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Thanks to ALL of you for all the information concerning a vibration damper. I will check it out and GREAT information on rebuilding them.
Tim
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Tim are those prices from Damper Dudes? A consideration before trying to put a 216 HB on the newer 235/261 (with 12v) would be the pulley width. I am not sure if the pulleys are the same diameter as the newer engines. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | There's a reason why the 216 and 235 didn't use the same damper. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Thanks again!  | | |
