9 members (carbking, Mike B, klhansen, Youngin' Tut 59, Pete1946, Gray_Ghost, BarryP, dt235sd, 1 invisible), 89 guests, and 3 robots.
Topics128,139
Posts1,056,758
Members48,454
Is it possible to get a NEW vibration damper ( harmonic balancer ) for the 216 cu.in. Chevrolet truck engine? Can they still be ordered from a GM dealer?
Tim
1970 VW Beetle
There are none available from GM.
NOS show up on eBay or swap meets now and then.
There are companies that rebuild them
There are also a lot of good used around also.
My Blog
Tim,
Find the part number (in the Parts Catalog - Old Online Chevy Manuals) and try to search for it here.
I do not gamble, but I'd bet is is no longer available from GM.
There are, however, a few GM NOS parts vendors with on-line catalogs. I cannot find a URL. A few years ago, I found 50 NOS, GM/GMC-only, big-bolt wheel nuts.
I'll look tomorrow (but, I still doubt you'll find one).
Do you necessarily need a balancer with the hand crank lugs?
I have built up a new balancer using a 6" diameter item for a small block V8 and a 2-groove pulley for a big block engine. It requires just a little machining to make the pulley grooves align properly, but the assembly is made up with all new parts.
You might try Damper Dudes @ 1-800-413-2673 or Damper Dudes. com
Or Damper Doctor.
http://www.damperdoctor.com/
-Michael
Please type slow, as I can't read very fast.
1939 Chevy/Central Fire Engine
1941 Chevy/American Fire Engine
1950 Chevy/American Fire Engine
More Photos in Me Gallery
Gas Pumper
Gas Pumper
Sounds like all you need is a replacement for the original? Most Salvage yards in the US have a BatPhone. You as the customer ask for a part, the yard you went to doesn't have it, they put the request out there over the BatPhone and someone answers. It would be a fun journey to the yard anyway! Take a puller made for it to save time! Good luck!
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
I wonder with rubber the way it ages, whether an NOS damper is a good thing.
1951 1 Ton Completed
I have a 235 engine but used as many parts from the 216 as possible, including the 216 damper with the crank lugs on it. I had it rebuilt by the previously mentioned Damper Dudes. They happen to be local and as I walked in the door with my old damper, only halfway to the counter the Dude says Chevy 216. I knew I was in the right place. Finished product was like new.
dg
Denny G
Sandwich, IL
$192.39 plus shipping 3/8" or 1/2" groove
$228.79 plus shipping double-groove
That's not to bad.
Gettin' bored yet Professor?
dg
Denny G
Sandwich, IL
Thanks to ALL of you for all the information concerning a vibration damper. I will check it out and GREAT information on rebuilding them.
Tim
1970 VW Beetle
Gas Pumper
Gas Pumper
Tim are those prices from Damper Dudes? A consideration before trying to put a 216 HB on the newer 235/261 (with 12v) would be the pulley width. I am not sure if the pulleys are the same diameter as the newer engines.
Deve
The Think Tank
There's a reason why the 216 and 235 didn't use the same damper.
Deve,
Various Damper Dudes 235/261 dampers on this page:
http://www.damperdudes.net//index.php?cPath=29
Gas Pumper
Gas Pumper
Thanks again! smile
Deve
The Think Tank
