1 members (69Cuda),
73
Mod | | | Forums66 Topics128,096 Posts1,056,487 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | Just a general question. Can one successfully drill a 1 3/8" through a flat piece of 1/8" metal without ruining the pc? Considering adding a marker light to a light bar I built for the 860 I am working on. Not a big deal if it isn't advisable. | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Bill, perhaps a hole saw or roto-bore would do a decent job of it. Was the light bar media blasted prior to powder coating? I've found that a local machine shop uses a conversion dip process (less labor intensive) that was rather ineffective in that the powder seemed to scratch off as if it were paint. Similar jobs done with a media blast prep of the surface, and you couldn't beat the finish off with a stick.. So I would consider what prep process was used as to whether the PC will adhere well through a drilling operation.. | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | Good point Robert. It was pretty clean (new metal) so not real sure what type of prep was done. Would 2 stage paint have been less likely to be affected by drilling? | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | I think my biggest worry would be the heat generated in the drilling process.
Alternatively: Can you contact the powdercoaters for advice? They might be able to offer some suggestions/tips. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | In any case, put a piece of painters masking tape around the area. Also, use a center punch first (after taping) so your bit doesnt wander. Use a sharp bit and spray some canola oil on the end of the bit to keep the heat down. Drill slow rpm for metal. The tape helps hold the PC down around the hole. DO check with your powdercoater to see if they have any other tips. I feel your pain, doing any drilling on fresh paint is always high pressure. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Bill, if the powder coat is fairly thick it will "chunk out" on you around the outside of your hole as you drill. The key is SHARP bit and as always start with a size or two smaller. I've done it successfully, but not cured and being a little heavy requires some patience. You can do it.....let us know your experience afterwards. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Yes, I like that advice alot... use very small drill bit to start.
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I favor step drills for clean cuts. Regular sharp drills and working your way up works too. Not uncommon for me to use 3,4,5 drills to get where I finally want to be.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Just a thought, but would slowly and carefully scoring it using a razor knife around the perimeter of the chosen drill size work? The knife would be of the hobby type with the wedge shape mounted in a pen type holder. I have used this method when cutting thin veneer. It's slow and gut wrenching, but usually works for that. | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | May also help to drill from the inside/back side. By the time the cutter gets through the panel it will have warmed up the temp a bit where there it less likely for chipping to occur. | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | Thank you all for all the great advise. I will let you know if I end up doing this and report back how it went.
| | | | | Joined: Feb 2004 Posts: 29,831 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,831 | 1 3/8" is a pretty big hole. I'd suggest scribing a line the diameter of the hole you want right down to bare metal (maybe make a template to trace around). Then center punch and drill a series of 1/8" holes all around the perimeter and "connect the dots" with a small saw blade, or a 1 1/4" hole saw, etc. Finish off the hole with a half-round file. A hole saw will wander unless the drilling is done in a drill press with the workpiece clamped firmly to the press table. Jerry
| | | | | Joined: Jan 2014 Posts: 86 Shop Shark | | Shop Shark Joined: Jan 2014 Posts: 86 | I used Blair brand "Holecutters" to cut the 13/16 hole on the fender for an antenna and a 3" to cut th hole above the rear view mirror for the speaker (both placed per accessory manual specifications). After using a center punch to dimple the surface, I was amazed at how precise holes were, with no "walking" and no damage to either painted surface. I wouldn't hesitate to use them to cut holes in another painted or powder coated surface.
Bob
1959 Chevy Apache Short Bed Step Side 1967 Cadillac DeVille Convertible 1967 Pontiac Firebird Convertible
| | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | For a hole that size you might want to see if you can rent or borrow a Greenlee hole punch. There is no danger you will damage the surrounding finish. | | |
