Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (Ponchogl, TooMany2count, baldeagle, Robert Crandall, Wheelie, ShopRag, cmayna), 39 guests, and 2 robots.
Topics128,006
Posts1,055,268
Members48,418
#1097889 04/17/2015 12:13 PM
i have a 69 1/2 ton with a 307 and it runs good but does use oil and smoke a litlle but not to much. what could be some of the causes for that?
jabos #1098000 04/18/2015 1:00 AM
valve guide wear, worn cylinder bore, worn piston rings are a few causes of oil consumption.
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
jabos #1098017 04/18/2015 3:04 AM
...if it smokes worse after it sits and you first start it up my vote would be the valve guides are worn out. If it does it going down the road then I'd say the rings are shot.
jabos #1098021 04/18/2015 3:32 AM
maybe there is sludge blocking the return holes in the heads.. i have seen that cause smoking in a other wise good engine
if you cant run with the big dogs...then stay on the porch
http://s202.photobucket.com/user/rcplumley/library/
