1 members (Jon G), 136 guests, and 1 robot.
Topics128,124
Posts1,056,334
Members48,439
#1097264 04/13/2015 11:46 PM
I need to replace the top cowl vent drain hose since mine is cracked and split. Is there a trick to replacing one like some type of lubricant that won't affect the rubber hose? I tried reversing the "old" hose and try the "unbroken end but it is like trying to get a noodle up a wild cat's rear. Ugh! Logic says to have someone push from engine compartment while someone guide from under the dash. Any help is appreciated.
"It wasn't broke but I still decided to fix it. Now its broke"
I really love my coon hounds
Pics at http://s982.photobucket.com/albums/...0truck/53%20Chevy%20truck%20Sept%202010/
It really is not too bad to install. Make sure you get the usual 1" long crusty piece removed underneath as seen here (you can also see how far on it goes).
https://www.flickr.com/photos/advance-design_parts_co/13115851445/in/set-72157631868452754
Use some personal lubricant or similar and set it as shown here if you want it "factory."
https://www.flickr.com/photos/advance-design_parts_co/8129474877/in/set-72157631868452754
Complete agreement with Brad's post (as usual) - worked well on multiple trucks for me. Use non-scented cheapest personal lubricant (Walmart, CVS, non-name brand).
Also I attach a detachable extension hose that goes down to below the block on the driver's side. That way, water exits below the block. You can easily remove the extension hose at a show. A tapered nylon/plastic hose connector is available at any hardware store.
That worked and stopped the leak there at the hose but I need to re-adjust the vent cover to seal down better.
