2 members (Southerntruck, Hush),
150
Mod | | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 144 | I need to replace the top cowl vent drain hose since mine is cracked and split. Is there a trick to replacing one like some type of lubricant that won't affect the rubber hose? I tried reversing the "old" hose and try the "unbroken end but it is like trying to get a noodle up a wild cat's rear. Ugh! Logic says to have someone push from engine compartment while someone guide from under the dash. Any help is appreciated.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Complete agreement with Brad's post (as usual) - worked well on multiple trucks for me. Use non-scented cheapest personal lubricant (Walmart, CVS, non-name brand).
Also I attach a detachable extension hose that goes down to below the block on the driver's side. That way, water exits below the block. You can easily remove the extension hose at a show. A tapered nylon/plastic hose connector is available at any hardware store.
| | | | | Joined: May 2010 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 144 | That worked and stopped the leak there at the hose but I need to re-adjust the vent cover to seal down better. Thanks John | | |
