7 members (52Carl, Goach2, Hotrod Lincoln, Oswald, Hugh63c10, TUTS 59, cmayna), 140 guests, and 4 robots.
Topics128,204
Posts1,057,294
Members48,467
Anybody know where to obtain one? Would really like to not relocate if at all possible.
1964 impala ss
1949 chevy 3100
I suggest taking your measurements and go into the store of your choice and select one to fit that has the CCA's and stuff that you want..or the most you can fit into the box. I like the DieHard group "G" I think is.
I believe you want group 24 but that is an old memory. Bottom line is "yes there is one that will fit and has for probably 40 years"
Well, I tend to stay away from these discussions now, lost a
good friend a while back simply because I didn't consult him
before asking the forum.
But all the info you could ask for is here:
Earlier Battery Size Thread
dg
Denny G
Sandwich, IL
1964 impala ss
1949 chevy 3100
I purchased two batteries for my 52 3100 at the battery shop. They charged me $74.00 for the floorboard one 6"1/2x 8"1/2 and the Auxiliary battery was little more.I think the core charges have gone up. They charged for the one Aux, which I didn't have $12.00.
__________________________________
Steve
1964 impala ss
1949 chevy 3100
pking75,
If it were me I'd replace those battery terminal ends that have the wire clamps with manufactured cables. Those ends work as a quick fix, but tend to corrode and get loose over time.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
heavy cables
...pic...
DADS50,
Those heavy cables are a must for 6v systems, he doesn't need them with his 12v system, #4 awg will work fine.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
wont hurt
I was mainly showing the clamps you were referring to. I should of rephrased it .
Thanks fellas she's not in for good yet anyways. Still got some electrical wiring to do.
1964 impala ss
1949 chevy 3100
