0 members (),
110
7
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | Anybody know where to obtain one? Would really like to not relocate if at all possible.
1964 impala ss 1949 chevy 3100
| | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I suggest taking your measurements and go into the store of your choice and select one to fit that has the CCA's and stuff that you want..or the most you can fit into the box. I like the DieHard group "G" I think is. | | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | I believe you want group 24 but that is an old memory. Bottom line is "yes there is one that will fit and has for probably 40 years" | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well, I tend to stay away from these discussions now, lost a good friend a while back simply because I didn't consult him before asking the forum. But all the info you could ask for is here: Earlier Battery Size Thread dg
Denny G Sandwich, IL
| | | | | Joined: Dec 2012 Posts: 78 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 78 | I purchased two batteries for my 52 3100 at the battery shop. They charged me $74.00 for the floorboard one 6"1/2x 8"1/2 and the Auxiliary battery was little more.I think the core charges have gone up. They charged for the one Aux, which I didn't have $12.00.
__________________________________
Steve | | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 |
| | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | pking75, If it were me I'd replace those battery terminal ends that have the wire clamps with manufactured cables. Those ends work as a quick fix, but tend to corrode and get loose over time. Mike B  | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | DADS50, Those heavy cables are a must for 6v systems, he doesn't need them with his 12v system, #4 awg will work fine. Mike B  | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | wont hurt
I was mainly showing the clamps you were referring to. I should of rephrased it . | | | | | Joined: Jan 2015 Posts: 125 Shop Shark | | Shop Shark Joined: Jan 2015 Posts: 125 | Thanks fellas she's not in for good yet anyways. Still got some electrical wiring to do.
