0 members (), 102 guests, and 3 robots.
Topics128,186
Posts1,057,319
Members48,469
I'm installing a new power booster brake set up on my 53 GMC 1/2 ton KEEPING ORIGINAL BRAKE PETAL I need the shaft retaining clip that holds the spring assembly and brake petal on shaft.Clutch petal replaced with spacer. Does anyone know what I can use for this ,shaft is 15/16.
The manual calls the clip a pin lock
Part number 359380
...click...
You will have to do some research. But chevs of the 40s offers a similar clip for large truck brakes
Part number 359380
...link...
This is not listed as the clutch/brake pin lock
It may or may not work
If someone has a brake/clutch pin lock removed maybe they can measure the o.d if its 1 3/16 its probably the same part?
Otherwise maybe try a e clip
Going to give it a try .They said it won't work but number in manual and the measurement are the same.Thanks for tip I'll let you know
I just used a spring clip of the right size.It has been on there for 5 years no problems.Or they call them C clip also.
Pete
I put it on seems ok. I also saw them in Jim Carter as warped washers
I have more zippers then a pair of cargo pants
I've used large C or E rings..joe
~ Joe
Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE.
Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke
....and let me add a large snap ring will even work if you find one that big.
thumbs_up I did wink grin
~ Joe
