| | | Forums66 Topics128,197 Posts1,057,259 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 21 | I'm installing a new power booster brake set up on my 53 GMC 1/2 ton KEEPING ORIGINAL BRAKE PETAL I need the shaft retaining clip that holds the spring assembly and brake petal on shaft.Clutch petal replaced with spacer. Does anyone know what I can use for this ,shaft is 15/16. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | The manual calls the clip a pin lock Part number 359380 ...click... You will have to do some research. But chevs of the 40s offers a similar clip for large truck brakes Part number 359380 ...link... This is not listed as the clutch/brake pin lock It may or may not work If someone has a brake/clutch pin lock removed maybe they can measure the o.d if its 1 3/16 its probably the same part? Otherwise maybe try a e clip | | | | | Joined: Sep 2013 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 21 | Going to give it a try .They said it won't work but number in manual and the measurement are the same.Thanks for tip I'll let you know | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I just used a spring clip of the right size.It has been on there for 5 years no problems.Or they call them C clip also.
Pete
| | | | | Joined: Sep 2013 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2013 Posts: 21 | I put it on seems ok. I also saw them in Jim Carter as warped washers | | | | | Joined: Aug 2014 Posts: 218 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 218 | I've used large C or E rings..joe
~ Joe Donate Blood, Plasma, Platelets and Sign Your DONORS CARD. The Life You SAVE Might Be Someone You Know and LOVE. Two possibilities exist: Either we are alone in the Universe or we are not. Both are equally terrifying. ~ Arthur C. Clarke | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....and let me add a large snap ring will even work if you find one that big. | | | | | Joined: Aug 2014 Posts: 218 I have more zippers then a pair of cargo pants | | I have more zippers then a pair of cargo pants Joined: Aug 2014 Posts: 218 | ....and let me add a large snap ring will even work if you find one that big.  I did
