0 members (),
122
Mod | | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2015 Posts: 15 New Guy | | New Guy Joined: Mar 2015 Posts: 15 | I know it has been asked and I found it once but I'll be damned if I can find it again. How do I decipher the stamped number above the starter on the engine. N233112CAL 02 is the number if anyone can help,that would be great. I found the casting the casting number 839132 and I know it is a 1940 216 engine.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I would guess that is a California assigned engine number. A Suburban I considered buying from CA had a similar number. Does it match your title? | | | | | Joined: Mar 2007 Posts: 55 'Bolter | | 'Bolter Joined: Mar 2007 Posts: 55 | Some info here Tech info 39 -40and here casting # page Welcome to the bolt lots of good info here | | | | | Joined: Mar 2015 Posts: 15 New Guy | | New Guy Joined: Mar 2015 Posts: 15 | Title has the the VIN # on it. I figured the California. I knew the vehicle came from there originally. I just didn't know if this number is just a serial number on the engine or does it mean something. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | As cletis posted, "N233112CAL 02" is not a GM code.
You have a replacement engine and that code was probably made-up by a CA DMV office/officer and put on the engine by a dealer/shop.
| | | | | Joined: Mar 2015 Posts: 15 New Guy | | New Guy Joined: Mar 2015 Posts: 15 | | | |
