5 members (55shaker, Hambone, dunfire, Rexville48, WICruiser), 114 guests, and 5 robots.
Topics128,014
Posts1,055,328
Members48,419
#1091488 03/15/2015 1:11 PM
I
I Offline
I know it has been asked and I found it once but I'll be damned if I can find it again. How do I decipher the stamped number above the starter on the engine. N233112CAL 02 is the number if anyone can help,that would be great. I found the casting the casting number 839132 and I know it is a 1940 216 engine.
I would guess that is a California assigned engine number. A Suburban I considered buying from CA had a similar number. Does it match your title?
Some info here
Tech info 39 -40
and here
casting # page
Welcome to the bolt lots of good info here
51 1 ton Panel
Betty, she's a handful
I
I Offline
Title has the the VIN # on it. I figured the California. I knew the vehicle came from there originally. I just didn't know if this number is just a serial number on the engine or does it mean something.
As cletis posted, "N233112CAL 02" is not a GM code.
You have a replacement engine and that code was probably made-up by a CA DMV office/officer and put on the engine by a dealer/shop.
I
I Offline
Ok. Thanks for the info
