Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
7 members (3B, WICruiser, Jay R, Wayne67vert, Phak1, DaveV, Hush), 122 guests, and 2 robots.
Topics128,274
Posts1,058,433
Members48,490
#1089275 03/04/2015 12:12 AM
I don't think the diff on my '53 GMC is original. Since I'm working in the brakes, I'd like to try to id it:ML 12 16 W.
gusco #1089322 03/04/2015 2:34 AM
Can you post some pictures of it?
Bill Burmeister
gusco #1089335 03/04/2015 2:54 AM
I'll try.
gusco #1089373 03/04/2015 5:17 AM
gusco #1089375 03/04/2015 5:20 AM
There is a "12345" just to the right of the carrier and the code provided above over by the brake bracket. There is evidence of other spring perches being torched off and the existing ones welded on.
gusco #1089380 03/04/2015 6:40 AM
*left of the carrier
gusco #1089389 03/04/2015 7:54 AM
That rear was not offered in GMC in 1953. From the picture it could be almost anything from a few years later. How many bolt holes do the wheels have?
gusco #1089402 03/04/2015 2:33 PM
6x5.5
gusco #1089430 03/04/2015 4:58 PM
Its GM, if you pull the cover off, the ring gear will be marked with gear ratio and date of manufacture. It will be on the outer edge. Ratio will look something like this 11-41 (3.73 ratio) 10-41 (4.10 ratio), and date will be something like 09-55 or 10-65 with the first number the month and second the year.
joe
gusco #1089432 03/04/2015 5:02 PM
3B Online: Content
3 Online: Content
Hy gusco, as crenwelge said that rear axle is from a much newer 1/2 ton, GM "12 bolt", (the number of bolts which retain the inspection cover)
gusco #1089437 03/04/2015 5:28 PM
Alrighty! Do I take the cover with me to the parts store in order to get the correct gasket for reassembly?
gusco #1089494 03/04/2015 11:51 PM
I found a little more info:3896839 gm52
gusco #1089511 03/05/2015 1:22 AM
Its a truck 12 bolt they used these into the 80's
Fel-pro RDS13391
or
Victor P27940
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
gusco #1089684 03/05/2015 10:35 PM
chug
gusco #1089738 03/06/2015 2:55 AM
Popped the cover off: 9/69, 9:37 (4.11).
Now the question becomes: Do I look for original wheel cylinders or wheel cylinders for a 1970? The ones that came off are Delco Moraine pt. #5450649
