2 members (Phak1, Tom McGrath),
119
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,274 Posts1,058,433 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | I don't think the diff on my '53 GMC is original. Since I'm working in the brakes, I'd like to try to id it:ML 12 16 W. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Can you post some pictures of it?
Bill Burmeister | | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | | | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | | | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | There is a "12345" just to the right of the carrier and the code provided above over by the brake bracket. There is evidence of other spring perches being torched off and the existing ones welded on. | | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | | | | | | Joined: Jan 2008 Posts: 4,985 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,985 | That rear was not offered in GMC in 1953. From the picture it could be almost anything from a few years later. How many bolt holes do the wheels have? | | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | | | | | | Joined: Feb 2000 Posts: 5,266 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,266 | Its GM, if you pull the cover off, the ring gear will be marked with gear ratio and date of manufacture. It will be on the outer edge. Ratio will look something like this 11-41 (3.73 ratio) 10-41 (4.10 ratio), and date will be something like 09-55 or 10-65 with the first number the month and second the year.
joe
| | | | | Joined: Nov 2005 Posts: 6,102 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,102 | Hy gusco, as crenwelge said that rear axle is from a much newer 1/2 ton, GM "12 bolt", (the number of bolts which retain the inspection cover) | | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | Alrighty! Do I take the cover with me to the parts store in order to get the correct gasket for reassembly? | | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | I found a little more info:3896839 gm52 | | | | | Joined: Dec 2006 Posts: 206 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 206 | Its a truck 12 bolt they used these into the 80's
Fel-pro RDS13391 or Victor P27940 | | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | | | | | | Joined: Feb 2015 Posts: 285 Shop Shark | | Shop Shark Joined: Feb 2015 Posts: 285 | Popped the cover off: 9/69, 9:37 (4.11). Now the question becomes: Do I look for original wheel cylinders or wheel cylinders for a 1970? The ones that came off are Delco Moraine pt. #5450649 | | |
