0 members (), 106 guests, and 0 robots.
Topics128,101
Posts1,056,181
Members48,436
#1087195 02/22/2015 5:01 AM
The threaded collar at the rear of the torque tube ball collar (see link to picture below) keeps backing out, resulting in a transmission leak. Any suggestions on how to make this thing stay put?
http://lymanhall.smugmug.com/Trucks/1953-Chevrolet-3100-Truck/i-PHq3jZm/0/L/Ball%20Collar-L.jpg
I can't find a torque value for tightening the collar, and have been using a pair of soft-jaw (curved-jaw) channel-locks. It gets loose after only a few miles' driving.
1953 Chevrolet 3104 1/2-Ton
More pix
put some thread locker (locktite) on it and let it sit overnight.
Note: Not sure on your model but most of these collars have a steel washer that goes in the screw cap, then the felt/cork gasket and then another steel washer. The felt/cork gasket gets squashed between the two steel washers as you tighten up the collar which helps it stay in place and keeps it from leaking.
Hope this helps...if all is good then you may want to "stake" the collar a little with a punch???
Thanks AC, I think I'll try a couple rounds of teflon tape first and if that doesn't go I'll try the Loctite.
More pix
I wouldn't bother with the Teflon tape. Go with the suggested Loctite. I suggest Loctite PST (Pipe Sealant with Teflon). Does wonders.
Craig
