| | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 33 | Bought a gauge cluster assembly from LMC Truck for a 1950 Chevy 3100. There are two Warning! stickers on the box and one on the square nut on the back of the oil pressure gauge that state:
"WARNING! Square nut on back of oil gauge must be secured before attaching oil line. Failure to do so may result in damage to gauge."
That nut looks really secure to me, as shipped. Is this warning us if we take it apart or do the three warning labels imply that we need to do something else to it? Confusing. I called LMC and they offered no meaningful information. Any thoughts? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | my GUESS would be that they have had complaints by owners that tighten the "threaded tube nut" on the oil line so tight that they twist the square nut then complain.
I think to make sure it is "secured" would mean to put an open end wrench on the square nut to hold it while tightening the tube nut. Just my opinion. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I think to make sure it is "secured" would mean to put an open end wrench on the square nut to hold it while tightening the tube nut. Just my opinion. That is what it means to me. I have over 30 years experience in aircraft hydraulics and I know better than to not use back up. | | | | | Joined: Jan 2013 Posts: 33 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 33 | Ah, now that makes sense. Thank you for clarifying! | | |
