11 members (Jay R, TUTS 59, Forty9, cmayna, Lostbuthaulinass, Woogeroo, Peggy M, Wayne67vert, Uncles51, greenie-reddy, 1 invisible),
105
Mod | | | Forums66 Topics128,134 Posts1,056,411 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | While installing insulation, I noticed that I seem to be missing an interior sheet metal panel. Behind the back of the seat, there was a small, curved sheet metal panel on each corner of the cab. The presence of screw holes indicate that there should be a longer, rectangular panel across the back, behind the seat. Is that correct? Where could I get one? Bob
BobS46
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Bob,
Do you have pics? Photographs would be a great help and might get you some answers.
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | Thanks for replying. It is hard to take a picture of a panel that you never had, but -I found a photo on Sheridan's site that shows what appears to be the missing panel. Not sure why there is an oval hole in the center, but here is the link - www.46chevytruck.com/images/46chevy/cabontrailer.JPG
BobS46
| | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | That is the interior panel that wraps the back window. There are two panels one each side that fit from the door latch side to the inner rib on the bottom. Passenger side is slotted to allow for gas tank filler. They could easily be made if you can't locate. I have two that I could take a picture of or could make you a pattern if needed. Hope this helps. Have fun and good luck Dan | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | Found a picture here .These were after I painted . One corner is in front of rear window panel. Dan | | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | Thanks. I was about to disagree with you, went back to Sheridan's picture and took a better look. He did have the upper panel loosened and sitting on the floor. Explains the oval hole. I guess maybe the only reason that there are screw holes down the length of the center support is because they made them all them same - reduced inventory. The hole patterns are the same. So thanks, I can move forward. I do have the two corner panels - just have to put the curve back in (thank you, powder coater). Bob
BobS46
| | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Seems you figured it out.
Tim.
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | |
