3 members (Hotrod Lincoln, TooMany2count, ranchojuan), 91 guests, and 3 robots.
Topics128,135
Posts1,056,423
Members48,441
#1083634 02/04/2015 10:13 PM
While installing insulation, I noticed that I seem to be missing an interior sheet metal panel. Behind the back of the seat, there was a small, curved sheet metal panel on each corner of the cab. The presence of screw holes indicate that there should be a longer, rectangular panel across the back, behind the seat. Is that correct? Where could I get one?
Bob
BobS46
Bob,
Do you have pics? Photographs would be a great help and might get you some answers.
Tim
1970 VW Beetle
Thanks for replying. It is hard to take a picture of a panel that you never had, but -I found a photo on Sheridan's site that shows what appears to be the missing panel. Not sure why there is an oval hole in the center, but here is the link - www.46chevytruck.com/images/46chevy/cabontrailer.JPG
BobS46
That is the interior panel that wraps the back window. There are two panels one each side that fit from the door latch side to the inner rib on the bottom. Passenger side is slotted to allow for gas tank filler. They could easily be made if you can't locate. I have two that I could take a picture of or could make you a pattern if needed. Hope this helps. Have fun and good luck
Dan
Found a picture here .These were after I painted . One corner is in front of rear window panel.
Dan
Thanks. I was about to disagree with you, went back to Sheridan's picture and took a better look. He did have the upper panel loosened and sitting on the floor. Explains the oval hole. I guess maybe the only reason that there are screw holes down the length of the center support is because they made them all them same - reduced inventory. The hole patterns are the same. So thanks, I can move forward. I do have the two corner panels - just have to put the curve back in (thank you, powder coater).
Bob
BobS46
Seems you figured it out.
Tim.
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
Moderated by  ndkid275, Phak1
