1 members (klhansen),
90
Mod | | | Forums66 Topics128,151 Posts1,056,999 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | SO my assembly manual has no information around how to secure the upper/side glass channel.
Is it screwed in at the top?
Use sealer/adhesive?
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I took time to try get mine "bent" just right then I used a small screw where it comes up out of the door shell then in the corner and at the end near the wing vent. They do not interfere with the window rolling up and down. So far, so good. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I did like Alvin. I even took the clips that were designed for it off. Then I studied the door frame and picked spots that were double walled and carefully drilled and tapped some 10/32 allen electronics component screws. tight and secure. Also there is a slot at the bottom the end slips into.
| | | | | Joined: Aug 2012 Posts: 338 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 338 | I have three small holes already on the top that are used for that. I was thinking maybe some 3M Weatherstrip sealer may also help. But I I see no leftover residue like this sealant was used previously.
I will use the screws first and see how that goes. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....as CASO mentioned. Be sure the end of the channel is tucked in the clip at the bottom of the metal channel guide that is down in the door on the hinge side. If not it'll be flopping around when the window is up and may give trouble later on. Let us know how things go. | | | | | | Neverdone Unregistered | | Neverdone Unregistered | In searching for a way to re-install the door window glass I came across this thread and though I would add my 2 cents What I did was notch about 3/4 inch out of the side of the channel where it butts the wing frame , I will slide it in before I tightened it up . The wing holds it up and in . http://i376.photobucket.com/albums/oo203/OldoginMd/003_1.jpgNow , does anyone have the procedure for re-installing the window glass ? My guess is that I need to loosing up the wing assembly and move it forward some to get the glass in ?????? Also when installing a new glass track do you just center it up on the bottom ? Thanks Dan | | | | | Joined: Mar 2010 Posts: 10,303 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,303 | You will need to completely remove the vent window assembly according to the Chevrolet Truck Shop Manual. Carl
| | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | Yep, I had to remove my vent window to get my glass out a few weeks ago. | | | | | | Neverdone Unregistered | | Neverdone Unregistered | You will need to completely remove the vent window assembly according to the Chevrolet Truck Shop Manual. Carl Carl , I looked in the shop manual before I asked this question what section is it ? I figured it needed to come out..... How about the placement of the bar on the bottom , I also figure that the window floats so it is not that critical is this so ? Thanks Dan
| | | | | Joined: Mar 2010 Posts: 10,303 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,303 | The bar at the bottom is self-centering I believe. To have the big glass fit the opening when closed, you leave the screws slightly loose at the track at the bottom, then roll the window up, then tighten the screws. Carl
