1 members (WICruiser),
209
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,102 Posts1,056,184 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 24 New Guy | | New Guy Joined: Jan 2011 Posts: 24 | The heater in my 54 pickup worked fine for many years. Now it does not get heat. Everything seems fine so I'm thinking it's the Ranco control valve. Is there a way I can confirm it's the valve? Are they difficult to rebuild? | | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | B52Gunner,
It could be the Ranco heater control valve, but I would check the heater core for any blockage before rebuilding or replacing the heater control valve. Disconnect your heater hoses and flush the heater core with a strong spray of water from a garden hose. That may correct your heat problem. If you have to rebuild the Ranco valve Jim Carter Truck Parts offers this service with your own core. Not sure of the cost. If you choose to rebuild it yourself, it is not too difficult.
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | I spoke with a radiator/heater core rebuilder and he said to flush the core the opposite direction of normal flow. Also, if your heater gets heat but very little, check your thermostat. My heater quit puting out heat in the middle of winter, when I replaced the thermostat the heater worked better than ever. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | fixit, you can rebuild the ranco valve yourself and the little gizmo to do it with is available from NAPO. I have the number somewhere if you need it so PM me. Denny Graham has photo's of his and I have several on my photobucket when I took mine apart and rebuilt it. Its more fun when you do it yourself....and lot less expensive!
EDIT: .....or you can come by the shop and we'll rebuilt it.
| | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | Achipmunk,
I don't need my heater valve rebuilt. Already rebuilt it. B52Gunner was asking about rebuilding his Ranco heater valve.
Tim
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I'd like to know a bit more about repairing one of these valves. Is the "diaphragm" the only replaceable part in them?
John | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes John, take it all apart and just change the rubber seal. Problem you will run into is bending the tabs. Gotta be careful bending them up cuz it's hard to get under them. Then you will have a hard time bending them back down tight so the whole thing doesn't leak. Then you have to hope that one of the tabs doesn't fatigue and break off. Alvin un-soldered the plug in the bottom and disassembled the whole thing. Hope your a good plumber/solder slinger if you choose to go that route. dg
Denny G Sandwich, IL
| | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | B52Gunner, A suggestion, Just take the Ranco valve out of the equation by hooking the heater up direct to the engine. If you get good heat,BAD Ranco valve. If still no heat,PLUGGED heater core! regards, steve sr.
| | | | | Joined: Jan 2011 Posts: 24 New Guy | | New Guy Joined: Jan 2011 Posts: 24 | Thanks Guys, I back flushed the heater core (clean water came out but still no heat)and then I by-passed the heater control valve and the heater put out heat. Now I'm sending my Ranco Heater Control Valve to the good folks at Jim Carter's for a re-build. Thanks again for your feedback, experience, & knowledge. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2011 Posts: 24 New Guy | | New Guy Joined: Jan 2011 Posts: 24 | So I got my Ranco Heater Control Valve back, all rebuilt. My question now is: Does it matter which hose goes where?
I seen in some pictures that the hose from the heater core was hooked up to the front port on the Ranco and the hose from the thermostat housing was connected to the rear port closest to the fire wall. Mine where the opposite when I disconnected it. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jan 2011 Posts: 24 New Guy | | New Guy Joined: Jan 2011 Posts: 24 | | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I've had my hoses hooked up opposite at the Ranco for 4 years Heater works great so I'm not sure if it really matters.
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | I don't think that the ranco nor the heater cares which way the hoses go. I would go with what the factory pictures above show, so that 'smart guys' can't pick on you for having it set up wrong. Carl
| | | | | Joined: Sep 2012 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 31 | So did the valve rebuild solve the problem?? My 52 is missing the valve all together. It had a gate valve inline and i've seen that on a couple other trucks too. Anybody have an extra Ranco valve that they would part with? Would like to get mine working correctly.
above all this old truck has taught me patients!
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | An inline valve will work just as well as the Ranco valve. It was an early attempt at regulating the heat thermostatically and does not do that job very well. To add to that they are prone to developing leaks. You can regulate the heat just as well with a manual valve. Unless you're striving for an accurate show points restoration, go for the manual valve.
Denny Graham Sandwich, IL
| | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | Denny - is this valve one you would place on the interior or directly on the water pump?
36 Chevy 1.5 ton - rusting away 52 Chevy 3100 - in progress 72 Chevy K20 - DD
PANTS UP DON'T LOOT! PANTS UP DON'T LOOT!
NEVER watch another man eat a banana.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | If---I were putting one in my truck it would be this type: Four-Seasons Heater Valve Denny Graham Sandwich, IL
| | | | | Joined: Sep 2012 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2012 Posts: 31 | Mine was just an old faucet valve that you adjusted under the hood. I like your idea a lot better! Thanks Denny.
| | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I have a Four Seasons 74828 valve on my defroster inlet hose mounted on the firewall and operated by a choke cable. Choke cable knob is under the dash where you can barely see it. Operates easily. In the summer I generally open it until the engine warms up then close it.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I have yet to find what the difference is between the Four Seasons 74827 and the 74828 heat control valves.
How did you mount your valve Harold? I don't see a mounting bracket. Normally they are simply installed in one of the 5/8" heater hose lines.
| | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | Thanks Denny - I had the exact same question.
| | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | I don't know if I found the difference in the two when I ordered it. I think I chose 74828 because it was cheaper.
I have 90 degree hose sections mounted on the outlet of the defroster. They make for a neater installation by keeping the hoses close to the firewall. The valve is in the inlet 90 degree hose and then the hose from the engine is attached to the valve. There is a place on the valve to attach the cable.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | So just to clarify Harold, your valve isn't actually mounted to the firewall, it's just close to it with a short section of hose?
Thought this would be obvious, but yes, the outer sheath of the cable has to be mounted solid in relation to the valve bellcrank, just as it is with the choke, throttle or defroster cables, that's the whole principle behind the way a push/pull control cable operates.
dg
| | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | No, it's not mounted to the firewall, just to the hose. The short 90 degree hose piece keeps it close to the firewall. The valve is supported only by the hose. The valve comes with a place to fasten the outer sheath of the cable. I can maybe take a photo next week. Right now it's up on the lift and I'm inside recuperating from a couple heart stents.
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I have yet to find what the difference is between the Four Seasons 74827 and the 74828 heat control valves.
Denny Graham Sandwich, IL Denny, Per 4-Season "The difference between 74827 and 74828 is the internal valve, it's clocked differently. The 74827 flows to the right and 74828 flows to the left". Mike B | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Boy that is a subtle difference. The 'flow' is straight through on either one. I think you mean the bellcrank 'throw' is to the left on one and to the right on t'other. If it were in line it wouldn't really make any difference other than the cable would cross over the hose on it's way to the dash. DG
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I think it internal ball only seals in one direction so they spin the internals 180* for left or right flow. Both are "pull open"... Mike B  | | |
