8 members (Hotrod Lincoln, carbking, tclederman, Bill Hanlon, 49choptop, Guitplayer, John L., Otto Skorzeny),
125
Mod | | | Forums66 Topics128,042 Posts1,055,501 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 181 | I'm kicking around an idea for a variation on the molasses bath idea. I'm thinking about adding corn starch or ??? to make it into a sort of gel that I can paint on the inside of the cab to remove surface rust. Think this might work? Any suggestions on how to improve the idea? Yes I do think too much and it is painful, but I just can't help it! It's what I do!
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless! My 1962 Chevy C-30 | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | Why bother when there are proven products already on the market? If you want to do it because you enjoy trying to make you own, then go for it. The best that I have found is lye and water but you must be very.... careful. Cecil..... | | | | | Joined: Sep 2003 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 181 | I think it's partly because I do enjoy making my own 'remedies' but I also like the thought of using something that doesn't involve chemicals and corrosives. I think I subjected my body to way more than enough chemicals in the 70's, don't need to add any more burdens to my system unless necessary.
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless! My 1962 Chevy C-30 | | | | | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | What about reducing the amount of water? Then covering with plastic sheeting? You could hold the sheeting in place with a lot of magnets? Otherwise I would think that it would dry out.
Is the Cab free from the truck? Can you lay it on its back? If so the just make a Tray that is, say 6" deep and line it with plastic.
Good luck and keep us posted on what you end up doing.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Sep 2003 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 181 | Thanks for the idea Brian. The cab isn't off so I pretty much have to do it in place. The plastic and magnets might work though. Dave
