4 members (54farmtruck, Rich'sToys, Southerntruck, klhansen), 332 guests, and 3 robots.
Topics128,167
Posts1,057,096
Members48,463
Anyone have experience using the MII front end on a 1950 Chevy PU w/o power steering? None of my earlier rides (60 F100,65 C-10,67 Camero) had PS and I'm getting plans together for a front/rear suspension change on my 50 3600. Any info is appreciated,
I have a M2 under my '40 pickup, with PS. I have a smaller Dia. Steering wheel , and wide tires up front, so PS is a necessity. Depending on how much weight you have up front, I think you can live without it' but why ? PS will improve resale value, and make it easier for wife to drive *g*
1940 Chevy KC 1/2-Ton
Small block engine and up to 225 tires---No. My 34 coupe has an all aluminum 4.6 Modular engine and 195 tires so p/s would be a waste of effort. You can reach through the window and turn it lock to lock on clean dry pavement. We use quite a few rear mount no p/s VW R&P units as this often helps with steering shaft alignment.
Evan
since you have the MII already under it adding the power steering rack n pinion should be fairly easy. Been running mine now for 15 years and not one problem.
I put manual in my 46 with sbc and and 225x15 tires and was ok but after just converting over to ps i can not believe i waited 4 yrs to change over. I say do it now.
mike
Necessary, no. But you're talking about a pretty heavy truck so it's recommended. If you were building a Model A I would say no but for this you'll be happier with PS.
My 46 GMC on Photobucket
Wheel offset plays a critical role in steering 'weight' too.
I experienced this with an O/T car I bought a few years ago,it had those hideous white 8 spoke wheels on it and it was like driving a tank.
I changed the wheels to a slightly narrower wheel 6" rather than 7" but with the correct offset and the difference was impressive to say the least.
More pix on Flickr.
