5 members (TPR57C, Bill Hanlon, Samantha, TooMany2count, 1 invisible), 149 guests, and 3 robots.
Topics128,186
Posts1,057,315
Members48,469
I have a plain Jane 350 to go in a '49 3100.
I am leaning towards a 1985-1990 700R4 transmission.
What would be the best rear axle ratio for this combination?
Carl
3:73 nice all around gear
What size rear tire are you running?
Stock tires and rims for a AD 3100.
3.73 would be real nice then. Best of luck to ya
V
VEW Offline
V Offline
Carl, I'm working on the same set up for my 41. My research on the 700r4 shows 87-92 was the better years. Can't remember what change was made for '87, but I can try to find it.
~ Victor
1957 3100 - moved on
Check a 200r4 also. Lower first gear ratio.
What year did they go away from mechanical speedometer?
Carl
My 88 Silverado has the electronic speedometer.
Fred
V
VEW Offline
V Offline
93 is when the shifting logic went electronic, but I think the electronic speedometer was a couple years before that.
It's my understanding the tailshaft (4 bolt) can be changed out from an earlier mechanical speedometer tranny, even a 350, to install the mechanical speedometer gear.
~ Victor
The 700R4 has a lower first gear that the 200, 3.06:1 in the 700, 2.74:1 in the 200. Also, the 200 was never used in full size trucks.
Bill Burmeister
You're right longbox, it was a smoother 1-2 shift I was thinking.
