| | | Forums66 Topics128,187 Posts1,057,311 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,309 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,309 | I have a plain Jane 350 to go in a '49 3100. I am leaning towards a 1985-1990 700R4 transmission. What would be the best rear axle ratio for this combination? Carl
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | 3:73 nice all around gear
What size rear tire are you running?
| | | | | Joined: Mar 2010 Posts: 10,309 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,309 | Stock tires and rims for a AD 3100.
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | 3.73 would be real nice then. Best of luck to ya
| | | | | Joined: Jun 2005 Posts: 1,003 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,003 | Carl, I'm working on the same set up for my 41. My research on the 700r4 shows 87-92 was the better years. Can't remember what change was made for '87, but I can try to find it.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Check a 200r4 also. Lower first gear ratio.
| | | | | Joined: Mar 2010 Posts: 10,309 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,309 | Carl, I'm working on the same set up for my 41. My research on the 700r4 shows 87-92 was the better years. Can't remember what change was made for '87, but I can try to find it. What year did they go away from mechanical speedometer? Carl
| | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | My 88 Silverado has the electronic speedometer. Fred
| | | | | Joined: Jun 2005 Posts: 1,003 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,003 | 93 is when the shifting logic went electronic, but I think the electronic speedometer was a couple years before that.
It's my understanding the tailshaft (4 bolt) can be changed out from an earlier mechanical speedometer tranny, even a 350, to install the mechanical speedometer gear.
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Check a 200r4 also. Lower first gear ratio. The 700R4 has a lower first gear that the 200, 3.06:1 in the 700, 2.74:1 in the 200. Also, the 200 was never used in full size trucks.
Bill Burmeister | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | You're right longbox, it was a smoother 1-2 shift I was thinking.
