| | | Forums66 Topics128,174 Posts1,057,048 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | Anybody know what tranny would have been standard with a 1952 GMC 450 Series with 3-71 GMC diesel engine? Might go look at one if it has overdrive clark. Gentleman selling doesn't know much about it. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy eagleuh1, according to my parts book which covers that year/size, the diesel trucks were equipped with the Clark 204VO (overdrive) transmission, hope that helps. | | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | Thanks 3B. He's going to look at it tomorrow morning. If it turns out to be an overdrive Clark, and it will work with my 270, I'll probably buy it then. The truck is pretty rusty, but he said the diesel is all there. | | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | Looks like a 204V0356 overdrive Clark. Would this transmission fit the bellhousing for the 270 with 5 speed Clark,202V323. What gear ratios would the 204V0356 have? Thanks. Jim | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | I'd like to see pictures of that "Rare" truck. You don't see many of those 3-71 General Motors Diesels (They weren't called Detroits until around 1965). Only available for two years(52,& 53), if i'm not mistaken. I had a chance to own one a few years ago, & didn't pull the trigger. Been kicking myself ever since.
| | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | Found the ratios. 1-6.06, 2-3.50, 3-1.80, 4-1.00, 5- 0.80, R- 6.00. I'm guessing the bell housing would be the same for the tranny end, just different at the diesel vs. gas engine end. Hope the input shafts are the same.Jim | | | | | Joined: Aug 2013 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 255 | Will post pics as soon as I have it. Will be going to look at Monday, Spanky. jim | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If it is rusty, most AD tin would fit.
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | A cab from a 1/2 ton up to a 450 will interchange. 450 Fenders and probably the hood are larger, but fenders from a 450 gas burner would. Back when they were being produced, everyone I know that had one was very disappointed in them because they were so underpowered. But now they are very rare and very much in demand as toys and collectors items. If its reasonably priced, I would buy it just for that reason. | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | Did you actually look at the truck or do you only have the posted pictures? If the engine etc. is complete. I have most of the stuff laying around to fix it. Also I wonder if the guy has anything like a forklift. It would be pretty hard to winch onto a tilt trailer with a wheel missing. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | One way I have moved a vehicle with a missing wheel, put a 2x4 or such under the brake drum, wet the trailer deck down, slide the wood on the wet deck, or put small dia. pipes under the wood.
| | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | If you were pulling it on frontwards,it should slide on relatively easily;it may be necessary to use a Handyman and pick up that corner a little to get over an edge,but if you keep pulling,the jack will rock forward and set the drum/backing plate down on the other side of the problem spot. (The drum MIGHT just roll along.) No big deal. Speed | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I tried calling the guy, but it looks like he already torched the motor out of the truck. I gave up trying to call him after I saw the ad for the engine. https://littlerock.craigslist.org/pts/4870891423.html | | |
