1 members (Peggy M), 105 guests, and 3 robots.
Topics128,151
Posts1,057,000
Members48,460
#1081094 01/24/2015 12:52 AM
Anybody know what tranny would have been standard with a 1952 GMC 450 Series with 3-71 GMC diesel engine? Might go look at one if it has overdrive clark. Gentleman selling doesn't know much about it.
3B Offline
Hy eagleuh1, according to my parts book which covers that year/size, the diesel trucks were equipped with the Clark 204VO (overdrive) transmission, hope that helps.
Thanks 3B. He's going to look at it tomorrow morning. If it turns out to be an overdrive Clark, and it will work with my 270, I'll probably buy it then. The truck is pretty rusty, but he said the diesel is all there.
Looks like a 204V0356 overdrive Clark. Would this transmission fit the bellhousing for the 270 with 5 speed Clark,202V323. What gear ratios would the 204V0356 have? Thanks. Jim
I'd like to see pictures of that "Rare" truck. You don't see many of those 3-71 General Motors Diesels (They weren't called Detroits until around 1965). Only available for two years(52,& 53), if i'm not mistaken. I had a chance to own one a few years ago, & didn't pull the trigger. Been kicking myself ever since.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Found the ratios. 1-6.06, 2-3.50, 3-1.80, 4-1.00, 5- 0.80, R- 6.00. I'm guessing the bell housing would be the same for the tranny end, just different at the diesel vs. gas engine end. Hope the input shafts are the same.Jim
Will post pics as soon as I have it. Will be going to look at Monday, Spanky. jim
Crusing in the Passing Lane
If it is rusty, most AD tin would fit.
A cab from a 1/2 ton up to a 450 will interchange. 450 Fenders and probably the hood are larger, but fenders from a 450 gas burner would. Back when they were being produced, everyone I know that had one was very disappointed in them because they were so underpowered. But now they are very rare and very much in demand as toys and collectors items. If its reasonably priced, I would buy it just for that reason.
Decided not to go for another big project, but if anyone else is interested
http://littlerock.craigslist.org/cto/4858380536.html
Did you actually look at the truck or do you only have the posted pictures? If the engine etc. is complete. I have most of the stuff laying around to fix it. Also I wonder if the guy has anything like a forklift. It would be pretty hard to winch onto a tilt trailer with a wheel missing.
One way I have moved a vehicle with a missing wheel, put a 2x4 or such under the brake drum, wet the trailer deck down, slide the wood on the wet deck, or put small dia. pipes under the wood.
If you were pulling it on frontwards,it should slide on relatively easily;it may be necessary to use a Handyman and pick up that corner a little to get over an edge,but if you keep pulling,the jack will rock forward and set the drum/backing plate down on the other side of the problem spot. (The drum MIGHT just roll along.) No big deal.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
I tried calling the guy, but it looks like he already torched the motor out of the truck. I gave up trying to call him after I saw the ad for the engine.
https://littlerock.craigslist.org/pts/4870891423.html
