6 members (Southerntruck, D B Cooper, hapydirty, Hush, Jims46, 5 Window 9434), 147 guests, and 2 robots.
Topics128,049
Posts1,055,675
#1079388 01/15/2015 4:21 PM
I have a 327 eng.&3 speed in the 55 panel,i built a good set of front mounts.now I would like to use 700r4 tranny.would it be alright touse the front mounts and the tranny mount? or should I use side mounts?
You need side mounts. The distance between the front mounts and the rear transmission mount is to far. I've seen a number of cracked transmission cases from poor mounting setups.
Don's answer times 2
