1 members (wilbur53),
92
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 152 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 152 | hi guys,
im looking to buy a chrome plated water inlet. ive seen some advertised as fitting SB chevy, do these also fit a 235?? all the adverts ive seen online list fitting v8 but not 235...are they the same?
also i have heard horror stories that aftermarket ones corrode badly, has anyone bought a good one?
cheers mike
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | They are not the same. On an SB engine the t-stat housing is cast into the intake (or block not sure which). The 235 has an external housing. There are a few different housings so finding a chrome one may take some searching.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I've had my share of the bad aftermarket ones at the outlet.....or maybe its just my luck. The chrome ones seem to somehow always leak. I had one that wasn't "flat" and one that cracked...but several that leaked on chevy small blocks but not sure about a 235.
| | | | | Joined: Feb 2003 Posts: 1,382 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,382 | I had chromed T stat housings leak and if you do get one sand the chrome off,years ago I read that the 216/235 T stat housings will bolt on a sbc but never tried it. | | |
