3 members (Wheelie, Peggy M, Tom McGrath), 85 guests, and 2 robots.
Topics128,195
Posts1,057,374
Members48,469
hi guys,
im looking to buy a chrome plated water inlet. ive seen some advertised as fitting SB chevy, do these also fit a 235?? all the adverts ive seen online list fitting v8 but not 235...are they the same?
also i have heard horror stories that aftermarket ones corrode badly, has anyone bought a good one?
cheers
mike
ODSS Lawman
ODSS Lawman
They are not the same. On an SB engine the t-stat housing is cast into the intake (or block not sure which). The 235 has an external housing. There are a few different housings so finding a chrome one may take some searching.
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
I've had my share of the bad aftermarket ones at the outlet.....or maybe its just my luck. The chrome ones seem to somehow always leak. I had one that wasn't "flat" and one that cracked...but several that leaked on chevy small blocks but not sure about a 235.
I had chromed T stat housings leak and if you do get one sand the chrome off,years ago I read that the 216/235 T stat housings will bolt on a sbc but never tried it.
