2 members (Ponchogl, Peggy M),
311
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,081 Posts1,056,077 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 134 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 134 | I have and offenhauser duel 1 barrel carb intake with 2 Rochester carbs and have the linkage between the carbs non progressive but I can't find the linkage from gas pedal to carb linkage help I'm dying to drive my truck Thanks for any help engine 235 1954
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Flattop, if you need parts I'd recommend posting in the Parts Wanted Forum. Someone going from 6 to a V8 may just have what you need laying in the shop. | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | How much are you missing? Do you have the bellcrank? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A follow-up to Jim's question (so we are not flying partially blind):
parts from gas pedal to carb: - rod from pedal to bellcrank - bellcrank - rod from bellcrank to carburetor
