3 members (klhansen, Hotrod Lincoln, 1 invisible), 80 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
#1078266 01/09/2015 9:42 PM
I have and offenhauser duel 1 barrel carb intake with 2 Rochester carbs and have the linkage between the carbs non progressive but I can't find the linkage from gas pedal to carb linkage help I'm dying to drive my truck Thanks for any help engine 235 1954
Flattop, if you need parts I'd recommend posting in the Parts Wanted Forum. Someone going from 6 to a V8 may just have what you need laying in the shop.
How much are you missing? Do you have the bellcrank?
A follow-up to Jim's question (so we are not flying partially blind):
parts from gas pedal to carb:
- rod from pedal to bellcrank
- bellcrank
- rod from bellcrank to carburetor
