3 members (Uncles51, Hanks custodian, JW51), 58 guests, and 2 robots.
Topics128,041
Posts1,055,479
Members48,424
#1077195 01/04/2015 7:18 AM
I am trying to complete my first ever restoration of my 1954 Chevy 3100 and the doors are a big problem. I regretfully threw away the original door hinges and I am having all kinds of problems getting the doors lined up with new replacement hinges. Also, I am now thinking the replacement weatherstripping is not helping. Does anyone know if I should try to find original hinges? Is there a better weatherstripping than what I got at the Truck Shop in Orange, CA? Thank you for your help.
Gary, most all of us agree the best rubber products, weather stripping, comes from Steele Rubber Products but I must say I've had good results with door stuff from Classic Parts or JCarter. It would be nice to get the doors adjusted then put the weather stripping on and let the door pressure "set" the rubber...and the doors will be tight!
I've read lots on door hinges and my opinion, along with lots of others, is that good originals are better than most new ones. If its any comfort to you I think its safe to say that 99% of us have problems getting the doors "like we want them".
I'm sure others with more experience will chime in.... and by the way, my doors on the panel still don't close "like I want them"!
You will have great difficulty in adjusting the doors with the door seal installed, regardless of which hinges you use. I would remove the seals and try to adjust what you have. Keep in mind that it is a challenge to take off a perfectly fitting door, then reinstalling it to fit as perfectly as it was to begin with.
That is why we all truly hate doors. All of us.
Carl
thanks, i will remove the rubber, wait and hope someone has at least the lower original hinges, and then start again
Gary U #1077548 01/05/2015 10:45 PM
I made a cradle that slips under the door and mounts to my floor jack.
Think U___U shaped with a 2.5" piece of pipe that slips down over the floor jack welded on the bottom.
That's not what I did but it's the idea.
I thought it made the fine tuning much easier...
Easy to slide out of the way to test close and it holds the door 'where it was' even swung wide open. (unless your lift leaks)
Give me ambiguity
or give me something else
