4 members (dogdaddy, Ponchogl, 2-Ton, 1 invisible), 72 guests, and 2 robots.
Topics128,037
Posts1,055,463
Members48,422
#1075717 12/28/2014 2:41 AM
Hi Guys: I have tried everything to loosen up my frozen 54 engine in my 49 1/2 ton. I plan to start looking at the interds. When I take off the head, do I need to remove the rocker arms or can I simply loosen the head bolts and leave the rocker arms in place? Will this procedure make life easier if I get the engine moving and start replacing everything???...any potential harm by doing it this way?
billm #1075720 12/28/2014 2:49 AM
No problem in taking the head off with the rockers in place, won't hurt a thing.
Bill Burmeister
billm #1075722 12/28/2014 2:54 AM
Thanks Bill: Any idea what I should look for when I am trying to determine why my engine won't turn over??
billm #1075726 12/28/2014 3:07 AM
most reasons that an engine won't turn will be obvious with the head removed, things that usually are easier to fix with the head off too, let us know when you get it pulled wink
Indy wink
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
billm #1075856 12/28/2014 11:33 PM
check the lifters.....and pull the pan to see if the rods will move back and forth. Just had a 261 stuck for years and found three lifters stuck and #2 rod "frozen" to the crank. Cylinder walls were fine. Had I pulled the pan and side covers first I would not have had to pull the head. Just more ideas.
billm #1076654 01/02/2015 12:08 AM
Good save,Alvin! Great Advice!!I hope you find your head's still in good condition. Good Luck!!
Mo' Tater
